Re: twin carburetors
Do the size will change something ?
And you were talking about type, it won't change anything whatever type i found ?
Yes, whatever SU you get will need to be rejetted -- none of them are jetted for the A12 engine. It'll run on the car (all gasoline engines require the same air/fuel ratio) but the dynamic characteristics change with every engine type (mainly throttle/acceleration changes, and fine tuning the a/f ratio). On an SU this means changing the needle jet and the dome spring
For example:
* A12/A14 factory twin carbs use the light dome spring
* All other Datsun factory twin carbs use the heavy dome spring
* SUs use one of many dome springs
Dome Spring
Jet Needle (also visible in previous photo)
Posted on: 2016/10/15 4:35
Subject Poster Date
     twin carburetors robch215 2016/10/14 17:58
       Re: twin carburetors smariese 2016/10/14 20:10
       Re: twin carburetors robch215 2016/10/14 20:17
         Re: twin carburetors ddgonzal 2016/10/15 0:37
       Re: twin carburetors robch215 2016/10/15 1:16
         Re: twin carburetors ddgonzal 2016/10/15 1:34
       Re: twin carburetors robch215 2016/10/15 1:59
       Re: twin carburetors Rallytwit 2016/10/15 2:28
       Re: twin carburetors robch215 2016/10/15 4:12
         Re: twin carburetors ddgonzal 2016/10/15 4:35
       Re: twin carburetors robch215 2016/10/15 4:56
         Re: twin carburetors ddgonzal 2016/10/15 5:13
       Re: twin carburetors robch215 2016/10/15 14:48
       Re: twin carburetors robch215 2016/10/17 1:50
         Re: twin carburetors ddgonzal 2016/10/17 5:19
       Re: twin carburetors robch215 2016/10/17 16:35
         Re: twin carburetors ddgonzal 2016/10/17 22:14
       Re: twin carburetors robch215 2016/10/17 22:39
         Re: twin carburetors ddgonzal 2016/10/17 23:15
       Re: twin carburetors robch215 2016/10/17 23:28
