A14 rebuild
Quite a regular
From South Africa
Hi Guys i would just like some help on rebuilding my a14 or getting a import a15 ive got enoug $ to buy a complete a15 but it needs to stay standard,where as i can spend some $ to rework the a 14 what do u guys think?
Posted on: 2004/6/22 6:31
Old Datsuns never die they just go faster
Re: A14 rebuild
Having had both in my 1200, I would go with the A15, you get more HP down low in the RPM range than an A14. I would also upgrade to the A14/A15 4-speed or 5-speed at the same time.
On the other hand it's pretty much a toss-up. If the A14 cost less, go with the A14. I can't decide which is better.
Posted on: 2004/6/22 7:14
Re: A14 rebuild
From Wamboin near ACT(canberra)
i got my A15. i was faced with the option of gettin the 1200 rebuild cause it has 375000 on it, but instead i picked up a a15 with weber, 3700 cam and extractors for 500 bucks. From what i have heard i would go with the a15!!!!!
Posted on: 2004/6/22 8:20
DAT10K
Gun metal 1200 ute, worked a15, sexy lil beast!!!
Re: A14 rebuild
From Invercargill, New Zealand
Definitely build the A14. You can get that forged crank spinning better than the A15 cast crank with some simple head work and a freshen up. The import A15's are most likely to be ute/van motors with a cam profile to suit. Actually it depends if you like revs or not I guess! At least if you re-build the A14 you know that what you have is fresh and done right whereas there is always a question mark with used import motors.
Posted on: 2004/6/22 9:10
Re: A14 rebuild
From Sydney
ive got an a14 in my coupe and im thinking ofrebuilding itsoon. just wondering what sort of money i would need to spend to get someone to do it? or is it easy enough to do myself and wat would i need to replace etc...???
Posted on: 2004/6/22 10:20
Street Tail Dancers
1200 coupe - A14
Re: A14 rebuild
Hey all I have got a A15 from a van, what do I have to do to it to make it go hard, but still drive able??
Posted on: 2004/6/22 10:41
To do something well is so worthwhile that to die trying to do it better cannot be foolhardy. It would be a waste of life to do nothing with ones ability, for I feel that life is measured in achievement, not in years alone.... Bruce McLaren
Re: A14 rebuild
will a standard a12 or 1200 4 speed gear box be ok through a mild a15.... i thought it would be providing you dont drop burnouts all the time... what do i care ive got 6 of them any way.
Posted on: 2004/6/22 13:25
Re: A14 rebuild
No, a standard 1200 gearbox is not strong enough. Think about it, Datsun used a heaver box behind A14s, let alone A15s. Plus I tried it ... easy driving and the box still broke.
Posted on: 2004/6/23 5:25
Re: A14 rebuild
Quite a regular
From Christchurch, New Zealand
I'm with Teretonga on this one.
If you want heaps of torque get the 15 but if you want a strong revvy motor the 14 is the way to go.
I'm sure rpms is the preferred option here or most of us would be at chevv8.com
Posted on: 2004/6/23 5:38
Re: A14 rebuild
If you want a strong revvy motor, build up the A15. I guess his budget only allows one or the other (stock A15 or built A14).
Posted on: 2004/6/23 5:56
