« 1 (2)
Re: Need help with b210/120y rear suspension!
RCA is not necessary. However, after changing front suspension, the alignment must be readjusted. That being said, spacers help
Posted on: 2016/10/17 0:21
okay well when my shocks come next week and the front suspension is 100% done, the rear suspension is gonna start getting worked on so i will see what happens.
Is getting the rear leaves reset a good idea or should i just use lowering blocks?
what is the difference?
or is it possible to remove the rear leaves and make some coilovers with little modification ? (haven't seen anything on the wiki about this )
Posted on: 2016/10/17 7:11
Is getting the rear leaves reset a good idea or should i just use lowering blocks? what is the difference?
* $200 vs $100
* Lowering blocks are reversible. Remove blocks or add thicker blocks as you like
* Resets are non-adjustable. If it doesn't lower your car enough, you can get them reset again, or add blocks. For too low, say if your car won't pass inspection, you can replace the springs or have them reset again
* On a BW68-equipped 120Y sedan, blocks make for poor/no access to the brake adjuster and brake bleeder
Posted on: 2016/10/17 8:02
« 1 (2)
