Re: 1050 hp Datsun 1200
too much work to make that head run, he has still to finish it off and no need since the class rules are so restrictive even for the stock 8v a series head setup.
A13 is a nice engine and can be had from boring and old A12 front dizzie to 76mm
and would be awesome for high revving turbo. CA18DET is proven and if you are after
a twin cam head the vauxhall XE heads fit straight on the A series but need belt
driven setup much like the mazda B3 twin cam head another member pioneered here.
The vauxhall head lines up bolt, bores, water and oil drain much better.
http://datsun1200.com/modules/myalbum ... php?lid=6672%3Cimg%20src=
http://datsun1200.com/modules/myalbum/photo.php?lid=26080
http://datsun1200.com/modules/myalbum/photo.php?lid=26082
http://datsun1200.com/modules/myalbum/photo.php?lid=26081
Posted on: 2016/11/2 3:25
From Snohomish, WA USA
Yes. Too much work. Go big but stay Nissan.
Posted on: 2016/11/2 16:37
'73 2 Door Sedan
Crower Stage 3 Cams/SS Valves
Forge CP Pistons/ Eagle Rods
Ford 8.8/Mini Spool/4.11
so many choices!
diesel & boost like an alloy head cd20et
https://www.youtube.com/watch?time_continue=7&v=gjH013ei_4Y
A13 is still a good jigga by boring out an A12
vg20e are sweet and compact, lower deck than vg30e
also a great stock engine with silky smooth revs
If you use a microsquirt or carb with megajolt
you can get rid of the dissie and looks even smaller
http://community.ratsun.net/topic/15979-carbed-vg30e-2door/page-2
http://www.doovi.com/video/ultramotiv ... er-vg30-240sx/ZnYXo46JaTU
Posted on: 2016/11/4 3:41
« 1 (2)
