Fitting a windscreen 1200 ute
Quite a regular
Hey guys. Has anybody fit their own windscreen and/or back window on the 1200 ute. If so, was it difficult?
Is it worth having a go at or best left to the pro's?
Cheers for any advice
Posted on: 2016/10/16 4:26
Re: Fitting a windscreen 1200 ute
From Hawaii, USA
Are you the patient type? If not than it's better left to the pros
If you have a go at it, start with the rear window, which is much eaiser to do. See the step-by-step at Installing Rear Window
The front window can be easily broken if you get in a hurry. See Windshield Replacement
Posted on: 2016/10/17 0:31
Quite a regular
Ok I'll check it out. Local guy wants $165 each to install so even if I can do the back one myself it's a good saving 👍🏻
Posted on: 2016/10/17 8:06
From Hawaii, USA
Here new glass + install is only $200 USD
Posted on: 2016/10/17 8:07
Quite a regular
Windscreen alone cost me $250
Posted on: 2016/11/30 0:39
Not too shy to talk
From brisbane australia
I recently did both on my ute, it was actually surpingly easy. About 2 years ago I tried and had a professional try on the same ute but because there was excessive bog around the frame we broke two screens. After I had the window frame taken back to bare metal and repaired properly putting the new screen in was easy.
Posted on: 2016/11/30 8:11
From Ormeau goldcosst qld
its simple bit of rope and a screw driver. done. ive done my ute a few times
Posted on: 2016/11/30 22:52
1980 datsun 1200 ute ca18det gt28 200hp
1/4 mile 13.357 at 104.52mph
