Re: Cutting out radiator support to make room for thermo fans
From Snohomish, WA USA
I tucked a fan out front of my larger radiator inside of the radiator support as well. When looking at the engine on the left, also cut out the sheet metal out front to allow more airflow.
You may not need a second fan if you do that.
Posted on: 2016/12/21 1:22
'73 2 Door Sedan
Crower Stage 3 Cams/SS Valves
Forge CP Pistons/ Eagle Rods
Ford 8.8/Mini Spool/4.11
Subject Poster Date
     Cutting out radiator support to make room for thermo fans Murvz 2016/12/21 0:38
       Re: Cutting out radiator support to make room for thermo fans ddgonzal 2016/12/21 1:17
       Re: Cutting out radiator support to make room for thermo fans datsa73 2016/12/21 1:22
         Re: Cutting out radiator support to make room for thermo fans ddgonzal 2016/12/21 1:28
           Re: Cutting out radiator support to make room for thermo fans Murvz 2016/12/21 5:53
             Re: Cutting out radiator support to make room for thermo fans datsa73 2016/12/22 3:49
       Re: Cutting out radiator support to make room for thermo fans DogoX 2016/12/30 17:51
