« 1 (2) 3 »
Re: Rear axle options - What to do in the US?
Get an old junkyard 9"
Then buy a custom-width Curry housing with axles ($1400). Put the used pumpkin in, install any gearset ratio you want
Posted on: 2017/1/9 4:59
Quite a regular
From Long Beach, California
Ok I'll check that route out. Originally I was hoping I could just get the custom axles from Curry and use everything else from an Explorer but my worry was whether the custom axles would fit inside a stock Explorer housing. I asked Curry twice and never heard back from them.
Posted on: 2017/1/9 7:02
From Snohomish, WA USA
I shortened a Ford 8.8 out of a Mustang Fox body. I think I took five and a quarter inches off of each side and ordered axles from Moser.
Posted on: 2017/1/10 1:45
'73 2 Door Sedan
Crower Stage 3 Cams/SS Valves
Forge CP Pistons/ Eagle Rods
Eaton M62 SC 10 lbs. Boost / 150hp Progressive Nitrous
Ford 8.8 Posi/4.11
Quite a regular
So you were able to use everything from the original rear and just get the new custom axles fitted and it worked out? I'll check Moser out, thanks!
Posted on: 2017/1/10 20:10
The Mustang 8.8 with rear disc brakes and LSD is much easier to find. You could even buy two used ranger axles ($85 each) and shorten the housing to match
With the Ranger 8.8 ($250) youll only need to buy one axle. If you aren't narrowing your search to 3.73 there are many available
* one in Littlerock CA
* two in Bakersfield CA
* one in Arroyo Grand CA
* two in Baldwin Park CA
... and many more
http://www.car-part.com
Posted on: 2017/1/10 21:58
Yes. Both side 5 1/4 ".
I use a 7" wheel with a 3.75" offset.
Check my build thread page 49, thread #488. That is where my 8.8 build start.
Axle lengths, page 50, thread #498.
Do it right and do both and not just a one side deal. Get 2 new axles.
Posted on: 2017/1/10 22:17
'73 2 Door Sedan
Ford 8.8 Posi/4.11
Good info there: datsa73 build thread page post #488
Shortening one side is doing it right when (for example) the Ranger rear axle assembly has from the factory one long axle and one short axle. It's been discussed in the Main Forum before
Posted on: 2017/1/10 22:33
Posted on: 2017/1/11 0:37
Quite a regular
Thanks for the links D and thanks for the build thread link Datsa! This is helping out a lot!
One more question...I've been searching the wiki and I can't find any kind of spec sheet regarding the lengths for a stock H145 rear axle assembly. Is that available anywhere? Was hoping to just have something to reference instead of measuring everything and possibly getting something wrong if I order a custom rear end.
Posted on: 2017/1/12 2:48
Instagram: @SpatialStage
Diff Widths measure yours to double-check the measurements
Posted on: 2017/1/12 4:13
« 1 (2) 3 »
