« 1 (2)
Re: A15 engine swap
A15 changes needed:
* A15 bolts right up to the 1978 1200 crossmember & gearbox
* Exhaust pipe is 3-bolt for A15
* Shorter clutch release bearing sleeve (Or use A12 flywheel)
* Air cleaner differs
* Larger radiator needed than stock A12
* 1978 should already have the 56A gearbox, which is strong enough for A15
Posted on: 2017/3/5 18:30
« 1 (2)
