Browsing this Thread:
1 Anonymous Users
replacing flywheel oilseal |
Removal Remove oil pan Remove rear main bearing Lift out old seal
If replacing the rear main seal when changing a clutch, you may remove it with the oil pan still in place:
Puncture seal with an awl, tiny screwdriver, or similar implement. Punch through the eddge of the seal, by gently tapping through with hammer Carefully pry out slightly and work your way around the circumference until free
anyone tried without removing the oil pan?
Posted on: 2017/2/27 15:29
Re: replacing flywheel oilseal |
i screw the oilseal and gently pullout with the plyer
Attach file: oil seal.jpg (67.04 KB)
Posted on: 2017/3/8 11:17
Registered Users Contentmaster Usermaster
wow that was leaking!
Posted on: 2017/3/9 4:06
