« 1 (2)
Re: R31 Diff
Yes, turn the input flange by hand. If only one axle turns, it is not LSD. If each axle turns different directions, it is not LSD
If both axles turn the same direction, grab one axle to prevent it from turning. If then the center flange won't turn it is LSD. If the center flange turns with one axle held still, it isn't LSD
Posted on: 2017/3/17 4:35
« 1 (2)
