(1) 2 3 4 5 »
EFI Manifold
From Lyngby, Denmark
Hey guys :)
I have designed my own throttle body and matching manifold so suit EFI.
It's designed as ITB's and with an injector for each cylinder.
It is a Roller-Barrel Throttle body design, and I can fairly easy make it suit larger engines and the like, but it is made to fit my A12, taking in mind a port job.
I was just wondering if anyone of you people would be interested in a set :)
I don't know the price of the whole set yet. But I can make the EFI manifold, CNC'ed in Alu, around 30 euro a set
Then shipping on top, wich depends.
Best regards
Toby
jpg  EFI_Manifold.jpg (63.41 KB)
20628_58f781dc9f307.jpg 720X600 px
jpg  Roller_Throttle_1.jpg (133.88 KB)
20628_58f781e6dfc31.jpg 511X430 px
Posted on: 2017/4/19 16:27
Re: EFI Manifold
From Creswell, Oregon USA
working prototype?
Posted on: 2017/4/19 16:53
An idea doesn't work unless you do.
Instagram @MD_Machine
Parler @MDMachine
Re: EFI Manifold
From Zimbabwe
Are you a n let to make these manifolds to suit Toyota RSI 43mm throttle bodies? That would be awesome.
Posted on: 2017/4/19 16:57
No skool like the old skool
Re: EFI Manifold
From Zimbabwe
Sorry meant to say are you able to make these manifolds to suit Toyota RSI 43mm throttle bodies? That would be awesome.
Posted on: 2017/4/19 16:59
Re: EFI Manifold
From RSA
looks good but do they work.I was wondering if the injector is not too close.I would'nt mind the mani only but for turbo --just close it and use single t/body. nice idea
Posted on: 2017/4/19 18:22
Re: EFI Manifold
Looks like these would be extruded aperture bodies?
Posted on: 2017/4/19 18:38
Parler @MDMachine
Re: EFI Manifold
I'm making the prototype in my spare time. It will look a little different ( Will upload a picture later today of the CAD ).
datster, There are two ways I could make them fit the RSI's, 1. make a 31mm pipe to a flange that suits OR 2. Design a set that is made to suit. There is a recess as you can see, and that is made to accept a pipe or flange which you could attach to whatever you'd like. I'll also make some flanges as that is needed by some. Then you could make the adapter yourself.
nismo1, with a proper injector that has a good spray pattern, it won't be a problem.
Mattndew, I don't follow? They will be CNC'd in alu.
Posted on: 2017/4/20 7:38
Re: EFI Manifold
From Mordialloc Victoria 3195
Am I correct in saying thats about $42 aus dollars for an EFI manifold set ( ie 2 pieces ) + postage?
If that's the case I'm very interested to see you do an oval port version.
dp
Posted on: 2017/4/20 8:52
keep it simple
Re: EFI Manifold
Yes zigmondo, that would be about right. postage comes ontop of the 42$
I could make a oval port version, but the original design i posted here is large enough to suit oval. It was made with a small port job in mind for my own A12.
It is Ø32, so big enough for oval
Posted on: 2017/4/20 9:20
Re: EFI Manifold
From Zimbabwe
I would prefer if you could make them to suit as I don't have access to welding machines and other tools needed to complete them myself.I don't know about other members but Toyota throttles are easy to find and affordable here in Africa.
Posted on: 2017/4/20 9:42
(1) 2 3 4 5 »
