« 1 ... 10 11 12 (13) 14 15 16 ... 18 »
Re: Kermit the beat up Sedan
From Geelong, Victoria
Maybe check the discharge pressure with a gauge. It might be passing on the inlet check valve when pressure is applied on the discharge stroke of the diaphragm.
Posted on: 2017/5/7 10:16
From RSA
Dude what we do [but this is diesel] disconnect at fuel pump and before tank --blow fuel pipe out with airline.IF tank has drain plug then drain into small tin --that way you can see if there is dirt in the tank [vehicle must stand for a while to let all the dirt settle at the bottom]Use thin film of grease on fuel filter rubber [if it's tin filter -throw away] glass filters can chip and crack and cause air leak/air lock.I would as a last resort lend a fuel pump and just check if it pumps --that way you'll know if your original pump is buggered.Our way of working ---never refuel when fuel truck is filling tanks at BP or shell cos that means the fuel is low at the petrol station and you don't know when last they have done a sludge test and believe me they also have dirt in the fuel [all at the bottom] just think about it when fuel pump kicks off and they say its empty use next pump
Posted on: 2017/5/7 18:23
From Mordialloc Victoria 3195
Have you tried to disconnect the fuel pump from the filter , then fill it directly though a small funnel.
Disconnect the fuel line from the carby and crank it over and see it it squirts
IE: prove its your fuel pump and not the carby or filter
Posted on: 2017/5/9 3:53
keep it simple
From MOOROODUC. Victoria
MASSIVE EMBARRASSMENT!
Checked the pump with a gauge = 1 Lb at the outlet
Replaced the top part of the pump with another (took a pump off a later model Ute) = 2 Lb
Still not pumping fuel out the outlet
Bought 20 litres of fuel and put that in the tank and - funny how you need fuel in the tank to pump to the carby
anyway I got it started and he runs !..... KERMIT LIVES!
Fuel gauge doesn't work, wipers don't work, indicators don't blink - oh no ....ELECTRICS...
Posted on: 2017/5/13 8:47
Edited by demacoz on 2017/5/13 12:47:26
You love elecs
Posted on: 2017/5/13 11:28
From RSA
dude you got no problems man I'm sitting with fiat strada ute with no flicker lights.The damn spaghetti munchers always try to be different,flasher unit only agents and you cant get ur fingers in and its under the steering column not with the fuses,globes are not normal off-set where one pin is higher noooo the sh...heads had to move the the one pin closer[2mm]to the other.The front flickers have no wiring at globe holder just flat plates that touch.GEEZ try finding a fault on that lot I HATE ELECTRONICS more than you do [oh and speed clips and screws and plastic clips that break --cos some clip out and some screw loose] DAMN grrrrrrrrrrrrr [still no flickers]
Posted on: 2017/5/13 15:59
It's always the little things that hang you up. Your analytical mind was working on the hard stuff first!
Anyway, glad to hear Kermit has a heartbeat now.
Posted on: 2017/5/14 5:28
Indicators was just the flasher can - fund another and they 'work'
would the reason some of the globes are extremely faint be that they might be the wrong wattage?
ALSO REAR W'Screen is IN!
Now to get those pesky windscreen wipers working and try to find the special nuts to hold them on.
Posted on: 2017/5/26 9:39
Want to come do my elecs now?
Posted on: 2017/5/26 12:31
Yes, for example if the dash globes (bulbs) are 1.7W but are supposed to be 3.4W they'll be 1/2 the brightness -- but both look exactly the same
Posted on: 2017/5/27 5:31
