« 1 (2)
Re: Speedometer Alternative To Datsun 1200
From Lisbon
1/8 NPT means 3.175mm?
3/8 NPT means 9.52mm?
I dont understand the sender they say is 1/8 npt
the outside coollar 3/8 npt
Myy measures dont match anything?
The original coolar has less than m16
Please clarify my confused mind?
jpg  unnamed (1).jpg (21.79 KB)
6267_594970183b3d0.jpg 480X640 px
jpg  unnamed (2).jpg (22.91 KB)
6267_59497026067bb.jpg 480X640 px
jpg  unnamed.jpg (22.46 KB)
6267_59497034ceee4.jpg 480X640 px
Posted on: 2017/6/20 19:50
* NPT is not metric
* Instead of measuring the hex, NPT is based on the threads
* NPT is tapering pipe thread, like the oil sender threads
* Temp sender is not tapering pipe thread, it is metric thread
You can buy an adapter from the gauge company. For example http://www.summitracing.com/search/?keyword=1/8+npt+adapter
Posted on: 2017/6/21 5:25
From Lisbon
Hi!
I have just received the M16*1,5 collar nuts, but doesnt fit, is to tight the older one fits well on A12 HEAD.
Comparing The thread seems to be diferent. One is made of steel other is another material made? Makes any diference?
Any help
jpg  COOLAR.jpg (26.37 KB)
6267_595d4f71a3c30.jpg 640X480 px
Posted on: 2017/7/5 21:45
Edited by Luigi on 2017/7/5 22:10:36
Edited by Luigi on 2017/7/5 22:11:10
Edited by Luigi on 2017/7/5 22:22:57
From Lisbon
The thread of collar nut is the same for A12, A14 and A15 Cylinder heads?
I have test the m16*1.5 nut on a A12 Cylinder head
My actualy cylinder head is similar to the enclosed image with no collar nut i need the collar bexcause i have changed the all gauges and i will need install the sender wich cames withe the temp gauge
jpg  motor.jpg (94.34 KB)
6267_595d51c02854c.jpg 592X789 px
jpg  GAUGESS.jpg (32.78 KB)
6267_595d53c2b5963.jpg 640X480 px
Posted on: 2017/7/5 21:47
Those photos are not related to the speedometer ????
* Yes, all Datsun A-engines use the same threads
* I would use an adapter instead of a collar nut
* A "collar nut" is used by the stock sender, but many aftermarket stock-replacement senders do not use it
* When using an aftermarket temperature gauge, have you tried using the stock sender?
Posted on: 2017/7/8 8:17
Re: Temperature Sender
This one uses a collar nut
This one does not use a collar nut
Posted on: 2017/7/8 8:24
you can go to any fitter and turner they will make a brass adapter to suit
I bought one off slovakia store on ebay it had one side with the thread I needed
but needed the other modified and cost me very little to get it done at a shop.
Temp is vital you get it right for obvious reasons.
Posted on: 2017/7/10 2:48
« 1 (2)
