« 1 (2) 3 »
Re: Removing rooted bolts
From Canberra
thanks Autokat, thats just what I needed to know does the plate on the shifter side of the gearbox seal anything in, or is it just a cover...Im thinking i might just drill the head off the bolt and not replace it
Posted on: 2004/6/25 12:59
drill and re- tap
Posted on: 2004/6/25 13:20
78 model datsun 1200 ute. A15 twin webbers, dogleg 5speed.
Jk Rubicon unlimited, 58 CJ3B Willys
From Canberra
drill and re- tap
Too much effort
Posted on: 2004/6/25 13:23
LOL ten minutes and its over!
Posted on: 2004/6/25 13:28
From Kingston , Brisbane
If you mean where the clutch cable goes into the bracket/lever ontop of the engine (right hand side when sitting on it)which I think you mean the answer is yes this cover is the clutch case and if you don't have all of the bolts in the sucker will leak I tried putting gasket goo on and nothing worked because the engine get's to hot .But another thought ......... If you can knock the top of the bolt off and take the cover off you should be able to get vice grips onto the part of the bolt that is sticking out and get the rest of it out that way .( if I'm picturing it properly in my head from memory it should work.
Because I bet your problem is that the case only gives you a minimum amount of room around the bolt ??? I think.
Wait till you see the bolts sitting above the oil filter on an old Suzuki ( that'll make you cry ).
Posted on: 2004/6/25 13:29
From Canberra
thats a good point about removing the cover to expose more of the bolt...if the punch doesn't work then thats what I'll try.
Thanks
Posted on: 2004/6/25 13:33
From T'ville
many times when steel bolts get stuck into alloy form corrosion or what ever you end up pulling most of the thread out with it. which means tapping a slightly bigger thread
Posted on: 2004/6/25 13:41
From Castro Valley,CA USA
I would try to drill the bolt with a small bit first then go larger and larger. The heat from the drill is sometimes enough to help get it out. Also some E-Z outs are better than others.
Speaking of drills,
left handed drill bits
Posted on: 2004/6/25 17:31
From Canberra
I got it out.
ended up drilling enough out of the head of the bolt that I could use a screwdriver and hammer a notch in the rim of the bolt, then it was just a matter of putting the screwdriver at the right angle, and hammering it around in a circle. It wasn't corroded, just in really tight.
I got the cover off and found that the chain had at some stage slipped off the front sprocket and chewed a hole in the alluminium gearbox housing, its less that 5mm long and 2mm wide, but it lets all the oil out. Thinking of filling it with solder...any ideas?
Posted on: 2004/6/27 1:19
Tyrie wrote:
I got it out.
.......good work!
errr u could fill it with solder but it wouldnt last long... solder is stronger when there is less of it.. in large amounts soldier is very week.. in small amonts soldier is strong.... if u cant get a bloke who knows how to weld aliminium ... get a new 1 ..... ive found with my moto that when something brakes dont rooot around for weeks trying to fix it.. just piss the #### part off and get a new 1..... dont solder.... it will come back to haunt u.... leave solder to the electricians
woodydat
Posted on: 2004/6/27 2:50
« 1 (2) 3 »
