Re: Removing rooted bolts
From Canberra
I got it out.
ended up drilling enough out of the head of the bolt that I could use a screwdriver and hammer a notch in the rim of the bolt, then it was just a matter of putting the screwdriver at the right angle, and hammering it around in a circle. It wasn't corroded, just in really tight.
I got the cover off and found that the chain had at some stage slipped off the front sprocket and chewed a hole in the alluminium gearbox housing, its less that 5mm long and 2mm wide, but it lets all the oil out. Thinking of filling it with solder...any ideas?
Posted on: 2004/6/27 1:19
Subject Poster Date
     Removing rooted bolts Tyrie 2004/6/25 12:06
       Re: Removing rooted bolts Autokat 2004/6/25 12:26
       Re: Removing rooted bolts dattodude 2004/6/25 12:27
         Re: Removing rooted bolts dazzasute 2004/6/25 12:36
           Re: Removing rooted bolts Tyrie 2004/6/25 12:47
           Re: Removing rooted bolts dattodude 2004/6/25 12:49
             Re: Removing rooted bolts Tyrie 2004/6/25 12:52
               Re: Removing rooted bolts Autokat 2004/6/25 12:56
                 Re: Removing rooted bolts Tyrie 2004/6/25 12:59
                   Re: Removing rooted bolts woodydat 2004/6/25 13:20
                     Re: Removing rooted bolts Tyrie 2004/6/25 13:23
                       Re: Removing rooted bolts woodydat 2004/6/25 13:28
                   Re: Removing rooted bolts Autokat 2004/6/25 13:29
                     Re: Removing rooted bolts Tyrie 2004/6/25 13:33
                     Re: Removing rooted bolts sunny 2004/6/25 13:41
                       Re: Removing rooted bolts ang94541 2004/6/25 17:31
                         Re: Removing rooted bolts Tyrie 2004/6/27 1:19
                           Re: Removing rooted bolts woodydat 2004/6/27 2:50
                             Re: Removing rooted bolts Tyrie 2004/6/27 3:04
                               Re: Removing rooted bolts Tyrie 2004/6/27 3:11
                                 Re: Removing rooted bolts phunkdoktaspok 2004/6/27 4:50
                           Re: Removing rooted bolts olboy 2004/6/27 7:55
           Re: Removing rooted bolts Autokat 2004/6/25 12:52
             Re: Removing rooted bolts Tyrie 2004/6/25 12:55
