cross member bolt holes
From RSA
just looking for second opinion -- i got this cross member for the A14 /A 15 for free and after stripping i could see why it was free. The middle piece is damaged --the right side more than the left [the bolt holes are slightly ripped ---well the one and this caused stress on the other plus one bolt is bent] must have been quite a knock. Soooo can welding work or should i just chuck it ?
Posted on: 2018/4/8 19:11
Re: cross member bolt holes
middle piece?
Any B110/B120/B140 crossmember from 1974-up works for an A14/A15
Posted on: 2018/4/8 22:30
From Brisbane, Australia
if it's badly damaged, you could unpick the towers and weld them to your x-member
Posted on: 2018/4/8 22:38
From RSA
yes thats correct D --was thinking of using a sleeve weld it in and take it down --worried the welding will weaken it. I thought about unpicking it but you still gotta weld it again. Oh almost forgot the one bolt is also bent-- mmmm just phoned schus nissan and they said ''discontinued'' DAMN the bakkie [ute] that built south africa and they discontinue it.The 1200/1400 was used all over in the industrial world --now it's kia hyundai,tata,etc that only last a year --this is why i bought a suzuki carry. Okay i'll figure something out --it's either unpick or cut small sleeve type goodies that can take the bolts and weld it in.gudgeon pin --cut off 5mm
Posted on: 2018/4/9 9:40
Edited by nismo1 on 2018/4/9 10:21:44
Edited by nismo1 on 2018/4/9 10:25:30
Welding won't weaken it -- if it is welded expertly
The good news is that it is not a special bolt. M10 thread, Medium carbon steel (grade 8.8) should be as good or better than original
Posted on: 2018/4/9 11:21
From RSA
thanks DD ---all the bs a man must go through trying to save AND the missus is watching.They dont understand--- ''what you wanna spend all that money on that old car'' moan moan
Posted on: 2018/4/9 17:17
