Re: A15 Piston Rings
From Fort Worth, Texas
Ok DD. Have some concerns now that I checked my ring gaps. Top ring is 0.014 and a tight 0.015 using a standard feeler gauge. 2nd ring is 0.012 and a tight 0.013. Haynes calls out a maximum 0.014 for the top and 0.012 for the 2nd ring. I am ok on the oil rings which measured between 0.022-0.024. Haynes calls out between 0.0118 and 0.0354. Top and 2nd ring are on the top end and slightly out of tolerance depending how accurate my feeler gauge is.
Posted on: 2018/4/12 3:34
If you have to jam the feeler gauge in, use the next smaller gauge. It should fit in with only a slight drag. If it is tight, that doesn't count
Posted on: 2018/4/12 10:52
« 1 (2)
