« 1 (2) 3 »
Re: T50 conversion kit
Matt, the A series auto bellhousing supposedly doesnt require much of a 5-8mm plate to mate to a T50. Im sure DD gonzales can find my thread where I tried to get one of the guys who did it but failed to get decent prices from a waterjet place.
Posted on: 2018/5/21 13:01
From Creswell, Oregon USA
I would love to see the flange idea.
I have tons of 19.05mm 6061 plates on the floor with enough surface area to do an adapter flange.
Posted on: 2018/5/21 15:25
Flange idea? Do you mean the adapter plate for the A-series auto bellhousing, or something to do with the driveshaft?
Posted on: 2018/5/21 20:16
Yes that is what I mean.
I am doing a T50 adapt to my A12
Posted on: 2018/5/23 14:14
Posted on: 2018/5/24 14:42
I think I can do something very similar
Maybe with two pieces.
Posted on: 2018/5/24 16:30
An idea doesn't work unless you do.
Instagram @MD_Machine
Parler @MDMachine
From Las Vegas USA
I bought an auto bellhousing for the "one day" when I adapted a tranny with better ratios. The T50 is a good box nut I'd love to see someone do an adapter plate for a Miata 5 speed. The 5 speeds can be had stupid cheap. The bolt circle on the Miata trans is larger than the A series so a plate might work. Of course at the end of the day it's likely simpler to do an adapter for something like T50 or Ford Type 9.
Posted on: 2018/5/25 3:15
six speeds are better than 5 , at least for a street car. My next 1200 will have a six. Better acceleration + more fuel economy. And cheap. The Miata six-speed is an Aisan AZ6 -- surprise! So is the Nissan 6-speed
EDIT: also an AZ6 -- Toyota J160 for 1G & 3S engines (E10 Toyota Altezza/Lexus IS200) also Toyota 86/Scion FR-S (subaru boxer engine)
Posted on: 2018/5/25 11:00
Edited by ddgonzal on 2018/5/25 12:03:08
$300 for an MX5 trans in the local Craigslist. Not a bad pricing but not the best for sure.
Posted on: 2018/5/25 16:05
Parler @MDMachine
From Las Vegas USA
The 5 speed is smaller and lighter than the 6 speed. Also the 5 speed ratios are the same as a mid close 4 speed. I used a mid-close box For many years I used a mid close box and on my moderately tuned motors it worked well.
Posted on: 2018/5/26 2:54
« 1 (2) 3 »
