Heat and Smoke damaged 1200 Coupe on TradeMe.
From Invercargill, New Zealand
Hopefully this will rise from the ashes - been a well built car with a long ownership.
Trade Me
Posted on: 2018/8/5 12:19
Re: Heat and Smoke damaged 1200 Coupe on TradeMe.
Saw that last night.
Certainly a really nicely built little car with some serious gear.
I am pondering over whether to have a crack at it myself but the big question mark is what sort of damage has the smoke done? If its been hot enough to melt the hood lining then one can only wonder what the wiring loom is like...
Lets see where the bidding gets to.
Cheers
Dave
Posted on: 2018/8/5 21:47
From Sydney
$8k to $10k worth of parts alone. Most of that in the motor alone, going by the build specs. I think if it sells for less than $10k it's a bargain.
Posted on: 2018/8/5 23:08
1971 B110 Sedan GX Spec
1970 KB110 Coupe Track Car
S13 caliper brackets for S13 b...
From Las Vegas USA
Off on a total tangent; does anyone know what brand of dry sump pump that is? I have one that looks identical.
Tom
Posted on: 2018/8/6 1:38
From Hawaii, USA
Online
Seems low temp damage, as the headliner is only partially melted, ditto for the cowl top grilles. The heat was outside the car (building fire). Engine alone gotta be worth a bit, and bidding starts at $1
out of auckland, is the owner a member here?
1972 Datsun 1200 B110 Coupe race car with log book.
Heat/Smoke Damaged in building fire. Was driving before fire.
Requires a lot of work and I have no idea what the rebuild cost would be.
Includes huge selection of spares.
Rego on hold, cert plate but would require a lot of work and re certifying before being road legal.
A15, 1564cc,11.5:1 Comp
Arias Forged Pistons & H-Beam Conrods
ARP Rod Bolts
Race Cam with Double Valve Springs
Chromemoly Pushrods, Custom Rockers
Ported Head, 2mm Oversized Valves, 3 Angle Seats
Balanced Knife Edged Crank & Flywheel
45mm Weber Carbs & Ported Manifold
Extractors & 2.25" Mandrel Exhaust
3 Stage Dry Sump, Griffin Cooler
10L Oil Tank, Braided Lines, Bored Oil Galleries
Custom Pulleys, crank trigger, Idler & Suzuki Alternator
4 x AEM Smart Coils, Link G4+ Atom ECU
Ali Radiator & Electric Water Pump
Rebuilt Nissan 60A 5 Speed
Custom driveshaft
Shortened H160 Diff, AE86 Cussco 2 Way LSD 4.67:1
Double Diaphragm Pressure Plate
Carbon Kevlar Clutch Plate
Wilwood 4 Pot brakes on 280mm Front Rotors
240Z Aluminium Drum Brakes
Wilwood Adjustable Brake Bias Valve
Bigger Master Cylinder, Braided Brake Lines
Front Coilovers with Bilstein Inserts
Rose Jointed Lower Arms
Adjustable Radius Rods & Steering Arms
HD Front Swaybar with Solid Mounts
Adjustable Camber Plates
Flattened Leaf Springs, extra leaf & 25mm blocks
Rear Panard Rod, Swaybar, Mount & Links
Koni rear shocks
Ali Door Cards, Rear Floor, 20L Fuel Cell
Homologated 6 Point Roll Cage
Fibreglass GX Bonnet, Front Guards, Bobtail bootlid and 100mm bolt on Flares, Front Spoiler
Skid Pan
Front Strut Brace
20L Fuel Cell, Electric Pump & Braided Lines
15 x 8" 0et Rota RKR Wheels
225/45/15 NT01 Nitto Semi Slicks
350mm Wider Track & 50mm Longer Wheelbase
Posted on: 2018/8/6 2:09
From Sydney
Frenzied bidding. Sold for $11,550
Posted on: 2018/8/12 23:38
From Hawaii, USA
Online
will it be fixed? or just parted out?
jpg  melted headliner 846230248.jpg (151.76 KB)
174_5b714d0b574d3.jpg 1200X900 px
jpg  melted cowl top grilles, mirrors 846230168.jpg (188.24 KB)
174_5b714d17c04eb.jpg 1200X900 px
jpg  smoke finish 846231067.jpg (180.79 KB)
174_5b714d23c6d02.jpg 1024X768 px
jpg  846229047.jpg (190.93 KB)
174_5b714d2eaa46d.jpg 1200X900 px
Posted on: 2018/8/13 10:19
