« 1 ... 14 15 16 (17)
Re: my new ride 1200 ute
From Look who's back in town
10sec car to tow a 10sec car. I like
Posted on: 2/5 8:25
Was B110 Sedan: L series
From Port Douglas. QLD
And we have flares and new rims. Handling has gone next level.
jpg  myflares1.jpg (84.92 KB)
16861_5aae3f33b565a.jpg 960X720 px
jpg  myflares2.jpg (63.94 KB)
16861_5aae3f409215e.jpg 960X720 px
jpg  mtflares3.jpg (65.38 KB)
16861_5aae3f4e166f5.jpg 960X720 px
jpg  myflares4.jpg (76.30 KB)
16861_5aae3f5cdc6c2.jpg 960X720 px
jpg  myflares5.jpg (68.48 KB)
16861_5aae3f6be4893.jpg 960X720 px
Posted on: 3/18 10:29
1200 ute
ca18det
Very nice, how's the clearance on the fronts?
Debating whether the sunny needs similar live in the future
Posted on: 3/18 12:27
Few more pics of the beast.
Suffering some ignition dramas so i'm upgrading to an aftermarket rb trigger setup. Have some new coilovers with koni adjustable shock courtesy of nick cross. Now i can run r32 front calipers ;)
Have decided with the lack of e85 and no firm commitment from any local stations up here in cairns to supply e85 that i will move forward with a nice water methanol injection setup from Prometh in the states.
Had a run at the drags but with the ignition dramas and traction issues in 1st and 2nd i ran a 12.2....My pb with the older setup was 12.1. I will return when its all setup properly and might throw some drag radials on too.
jpg  datto raizo5.jpg (90.88 KB)
16861_5adc521e43988.jpg 960X573 px
jpg  datto raizo2.jpg (86.04 KB)
16861_5adc522c133c3.jpg 960X614 px
jpg  dattoraiz03.jpg (58.14 KB)
16861_5adc523c47b78.jpg 960X640 px
jpg  datto raizo 4.jpg (152.87 KB)
16861_5adc524778a73.jpg 960X640 px
jpg  datto raizo 6.jpg (180.58 KB)
16861_5adc52573c319.jpg 640X960 px
16861_5adc5265c8a65.jpg 640X960 px
Posted on: 4/22 10:16
1200 ute
ca18det
Very nice , very nice
Posted on: 4/22 11:50
Bit more of an update for those that don't follow elsewhere.
Well since the last post there has been some notable changes once again.
-Hi-octane motorsports rb trigger kit was modified to work with the ca18det
-New struts and brake setup from supafatto
-Rear roll cage in the tray
-Methanol Injection setup for more boost
-Diff gears reverted to 4.11 from 3.7
-rear handbrake setup modified to actually work properly
-new brake lines
-tunes x 2. I post trigger kit install, one post meth install.
-Harnesses, clubman style
After the trigger kit install we got some clean power runs on the dyno and picked up 30hp without any changes to the tune. Amazing how much difference a clean trigger signal can improve everything. The car then ran an 11.6 at the drag strip on toyo proxes r888r with a 2.4 sec 60ft and top mph of 125.
Methanol injection with a twin nozzle post intercooler setup gained me another 60hp with a light spray and allowing me to increase boost an extra 7psi safely to 28psi. Timing was not touched and there is def more to explore with this setup but in its current state if the system was to fail it will not blow my engine up. The cooling benefits are unreal. On wot im seeing sub zero temps on the air inlet temp sensor which is positioned behind the throttle plate. I cannot recommend a simple meth kit enough even just for cooling and cylinder head cleaning purposes even without a tune for it.
Safety had been playing on my mind and after seeing some images of a fellow owners accident i decided to put a half cage in the rear. Although not full proof it is still legal in qld and adds a layer of safety that was not there before.
The goal now is to compete in the sprints and hill climbs in townsville...driving to the event and back.
Ill post up some more pics soon.
Posted on: 9/8 3:51
1200 ute
ca18det
Forgot to mention i plumbed the screamer pipe back in for less hassle from the police. Also threw in a complete new exhaust system with blast pipes for extra jdm points.
jpg  cage2.jpg (77.75 KB)
16861_5b933aef926b3.jpg 960X720 px
jpg  cage3.jpg (69.77 KB)
16861_5b933afc9c9df.jpg 720X960 px
jpg  beforeinstall.jpg (87.25 KB)
16861_5b933c6aa44a7.jpg 960X754 px
jpg  blasties.jpg (133.03 KB)
16861_5b933c7889240.jpg 720X960 px
jpg  cageagain.jpg (129.79 KB)
16861_5b933c842306e.jpg 960X960 px
jpg  cagebw.jpg (89.56 KB)
16861_5b933c907e6c6.jpg 960X960 px
jpg  cagewithharnesses.jpg (89.30 KB)
16861_5b933c9e3fe55.jpg 960X720 px
jpg  goproengine.jpg (114.53 KB)
16861_5b933ca9f175d.jpg 960X720 px
jpg  harnessesarein.jpg (104.67 KB)
16861_5b933cbd979d4.jpg 960X960 px
jpg  methoptima.jpg (82.07 KB)
16861_5b933cce77608.jpg 720X960 px
jpg  methpipe.jpg (164.58 KB)
16861_5b933cdec98df.jpg 720X960 px
jpg  methtune.jpg (148.94 KB)
16861_5b933ceed8818.jpg 960X960 px
16861_5b933cff152b4.jpg 960X960 px
jpg  raceready.jpg (171.90 KB)
16861_5b933d1013c54.jpg 960X720 px
jpg  triggersetupinstall.jpg (102.50 KB)
16861_5b933d2034038.jpg 720X960 px
Posted on: 9/8 4:09
1200 ute
ca18det
From Mordialloc
Nice job - what a handful that would be.
Posted on: 9/12 0:03
'79 B120 (TURBO EFI A15 + 60 ser.5spd )
'83 Clubman 7 with worked A15 + 63A 5spd
'73 1200 Coupe Mild A15 5spd lsd
keep it simple
