« 1 ... 84 85 86 (87) 88 89 90 ... 96 »
Re: Super Bee KA24DR Sedan
From Snohomish, WA USA
Well I did the block radiator test and it came up negative. I'm sceptical. The liquid should turn from blue to yellow and I got nothing after 10 minutes so I put at the tail pipe and it took 3 minutes just to turn green. I don't think the 110 Octane makes a difference.
Ordered a custom aluminum racing radiator so after that's installed more than likely it will be a new head gasket.
Posted on: 2018/9/1 2:54
'73 2 Door Sedan
Crower Stage 3 Cams/SS Valves
Forge CP Pistons/ Eagle Rods
Eaton M62 SC 10 lbs. Boost / 150hp Progressive Nitrous
Ford 8.8 Posi/4.11
Posted on: 2018/9/1 2:56
Edited by unfamilia on 2020/3/29 12:17:22
Well a Cometic Gasket is $90 and a Tomei is $110. After that it's just a pain in the ass to pull everything apart. For $300, I can replace a radiator in 10 minutes. 👍
Posted on: 2018/9/1 3:01
'73 2 Door Sedan
Ford 8.8 Posi/4.11
Doubt if it's the head gasket ... more likely the fan
Cometic copper gasket needs special deck & head prep
Posted on: 2018/9/1 11:10
Radiator showed up. 2 core instead of my old single. 50mm thick instead of my old 30mm. Basically the same - length but I'll have to modify the mounts to get it in. Maybe I'll get a new fan setup as well.
jpg  IMG_20180911_100222.jpg (42.14 KB)
39_5b97f52e045a5.jpg 432X265 px
Posted on: 2018/9/11 18:04
'73 2 Door Sedan
Ford 8.8 Posi/4.11
Radiator fits nicely and is working. I ordered a new fan thermostat plug for the radiator. The current one was 95c - 85c which allowed the temperature to raise up a little bit. I ordered a Fiat plug out of England that is 90c - 80c. Should keep the temperature down. I do still have a fan "ON" override switch.
Posted on: 2018/9/20 5:45
'73 2 Door Sedan
Ford 8.8 Posi/4.11
Posted on: 2018/9/20 12:09
Edited by unfamilia on 2020/3/29 12:21:23
Well I've ordered two fan temp switches since then. The 90-80c switch was still too hot so I ordered an 82-77c switch which was too cold so I have a 87-82c coming in the mail. If that doesn't do the trick I'll just order an adjustable fan switch from Summit Racing.
Also considering upgrading my MSD Ignition box. I currently run the StreetFire Series which is an introductory box. Thinking about ordering the Digital 6A box. It puts out a better spark.
The goal is to break into the 10's next season. 🙂
Posted on: 2018/10/24 18:13
'73 2 Door Sedan
Ford 8.8 Posi/4.11
Some recent photos.
New radiator installed with relocated fan switch sensor.
And newly installed MSD 6A which throws a better spark than my old MSD Street Fire Box.
Am finally going to schedule a Dyno tune soon. Been talking with the local shop.
Need to know:
1. Running Fat or Lean
2. Best Ignition Timing setting
3. Best Spark Plug Gap
4. Best RPM shift for Maximum Horse Power
5. Over all Horse Power output on Motor and also on Nitrous.
jpg  radiator.jpg (168.51 KB)
39_5c2c2afcdc5b5.jpg 450X800 px
jpg  engine.jpg (179.05 KB)
39_5c2c2c2b61365.jpg 800X450 px
jpg  msd.jpg (130.70 KB)
39_5c2c2c361db39.jpg 800X450 px
jpg  shifter.jpg (109.46 KB)
39_5c2c2c41baf99.jpg 450X800 px
Posted on: 2019/1/2 3:22
'73 2 Door Sedan
Ford 8.8 Posi/4.11
looks good
Nissan puts their temp senders in the tank bottom or in the lower hose, dunno if that makes a differene
Posted on: 2019/1/2 3:55
