intake manifold plenum volume: how big should it be?
I'm thinking about moving to fuel injection, after reading the datsun1200 entry on how comparatively easy it is. Since I don't have an EFI manifold I'd have to build one, which is okay, but I'm wondering: for a non-racing daily driver, any guesses as to the plenum interior volume? I've read a lot of estimates and calculations, but I suspect "whatever Datsun did" is probably the right answer.
Thoughts?
Posted on: 2019/2/26 15:27
Re: intake manifold plenum volume: how big should it be?
ZERO plenum volume for best HP
Posted on: 2019/2/26 21:01
That is sweet. What ITB's are those?
I'm partly interested in a plenum because I may boost the engine at some point, at which point I know volume doesn't matter so much because the pressure makes up for it. But that's a huge project so getting it driving with FI first seems like a good idea.
Posted on: 2019/2/27 3:45
Those are 35mm motorcycle throttle bodies. When you have four ITBs u dont need a plenum
Where a plenum really helps is when you have only one throttle feeding four cylinders. Like this EFI manifold (127 hp dyno'd)
Posted on: 2019/2/27 8:09
Okay, that's really cool too. What ITB is that? It looks like all it needed was holes redrilled to make it fit onto a stock intake manifold? That would make my life a lot easier.
So how do people manage fuel flow through a single injector? Make it four times as large, or have it operate at four times the duty cycle?
Posted on: 2019/2/28 3:31
If you have four injectors, u need to make them each four time smaller than a single injector. The one in the photo is an inexpensive 800cc injector
The throttle body on the stock intake is a 40mm Hyundai Accent 1995-1999 part. See $1200 EFI Turbo A12 (the EFI doesn't require the turbo, and it all fits on a stock A12 -- stock block and stock head)
Posted on: 2019/2/28 8:09
