Nismo Intake Manifold Gasket NLA
From Las Vegas USA
I went to order the DCOE style intake/exhaust gasket 99996-H1150C and was told it's no longer available.
I've ordered 2 GX manifold gaskets from Bprojects.
This post is just a FYI.
Posted on: 2019/3/15 3:40
Re: Nismo Intake Manifold Gasket NLA
From Sydney
Tom, The Tomei Gaskets are up to scratch also. can be a bit pricey. fleabay example.
Tomei Manifold gasket
Posted on: 2019/3/15 3:59
1971 B110 Sedan GX Spec
1970 KB110 Coupe Track Car
1970 KB10 Coupe
S13 caliper b...
Hi Tom,
I have only ever used high temperature RTV ( silicon ) and never had an issue. Just got to make sure the surfaces are true and thoroughly cleaned. Locktite 'Master Gasket' is also good on the inlet manifold.
Cheers
Dave
Posted on: 2019/3/15 19:05
Hi Tom,
Cheers
Dave
From Las Vegas USA
Dave what I'd done for several years was take the standard oval port gasket and carve the intake using a dremel.
Posted on: 2019/3/16 0:48
