« 1 (2) 3 4 »
Re: Brake upgrade advice
From Sydney
Thanks for the replies, have a been informed well. Now to build a nice brake setup
Posted on: 2018/2/4 13:46
Not too shy to talk
From Kenya
Will Hilux caliper bolt on direct to B210 strut?
Posted on: 3/16 1:16
From Hawaii, USA
The larger A10 "Stanza" and B310 struts have the same caliper bolt pattern as the Sumitomo S12+ caliper used on the Hilux. But the smaller B210 struts have a smaller bolt spacing
The Hilux calipers are not recommended because they are very heavy cast iron. They are sometimes used as a budget choice when fitting large brake rotors but the better choice is a light alloy 4-piston caliper (such as Volvo, Nissan Skyline R32, or Mazda RX-7). These require much larger disc rotors than the 120Y
For the 120Y the normal Brake Upgrades will work -- they are listed for the 1200 (B110) but the early B210 is nearly identical
Posted on: 3/16 7:42
Not too shy to talk
From Kenya
Sometimes info here is confusing. Checking this out. 120y/B310 .
jpg  2019-03-16 13.09.58.jpg (59.23 KB)
17927_5c8cca67acecb.jpg 1100X408 px
Posted on: 3/16 9:57
Not too shy to talk
From Kenya
For the RX7 adapter for my strut, where can I buy online?
Posted on: 3/16 10:27
Not too shy to talk
From Kenya
I already got 258mm discs. That will serve the purpose?
Posted on: 3/16 10:30
From Melbored
Is SOufrika a hard place to get parts from?
sure you can get some late bits from there???
Posted on: 3/16 11:04
why you are slaves to Usury https://www.youtube.com/watch?v=FEheU28ea3c The Anzac Deception not know by modern Australians http://www.anarchistmedia.org/pdf/The-Anzac-Myth.pdf ""
Not too shy to talk
From Kenya
It's really hard here. And machine work is always over priced.
Posted on: 3/16 11:37
From Melbored
you wont need machine work if you can source Bakkie front struts
Posted on: 3/16 12:15
Not too shy to talk
From Kenya
I think this is possible. There was production in S.A. I'll try source them. What's the caliper bolt spacing of those struts?
Posted on: 3/16 12:48
« 1 (2) 3 4 »
