Re: 60A bell housing bolts
The purpose of the spigot bush (aka pilot bearing) is for the manual transmission shaft to ride in when you push the clutch pedal down
Normally they last the life of the car, but if they need replacing for some reason they are tricky to remove. The two methods I've heard of are cutting/chiseling or hydraulic removal (some grease and a blow from a hammer pops it right out)
Posted on: 2019/4/6 1:24
Subject Poster Date
     60A bell housing bolts TexasMidget 2019/3/26 2:16
       Re: starter motor bolts ddgonzal 2019/3/26 4:13
       Re: 60A bell housing bolts ddgonzal 2019/3/26 5:21
       Re: 60A bell housing bolts TexasMidget 2019/3/27 3:10
         Re: 60A bell housing bolts ddgonzal 2019/3/27 3:51
           Re: 60A bell housing bolts ddgonzal 2019/3/27 4:06
       Re: 60A bell housing bolts TexasMidget 2019/3/27 4:08
         Re: 60A bell housing bolts ddgonzal 2019/3/27 4:53
           Re: 60A bell housing bolts coxsteve 2019/3/31 3:31
       Re: 60A bell housing bolts Rallytwit 2019/3/31 19:24
       Re: 60A bell housing bolts TexasMidget 2019/4/1 5:32
         Re: 60A bell housing bolts ddgonzal 2019/4/1 11:01
           Re: 60A bell housing bolts ddgonzal 2019/4/1 11:44
       Re: 60A bell housing bolts TexasMidget 2019/4/2 3:56
         Re: 60A bell housing bolts ddgonzal 2019/4/2 6:20
           Re: 60A bell housing bolts ddgonzal 2019/4/2 7:36
         Re: 60A bell housing bolts ddgonzal 2019/4/2 7:49
       Re: 60A bell housing bolts TexasMidget 2019/4/3 3:23
         Re: 60A bell housing bolts ddgonzal 2019/4/3 3:50
       Re: 60A bell housing bolts TexasMidget 2019/4/3 4:27
       Re: 60A bell housing bolts TexasMidget 2019/4/3 4:46
         Re: 60A bell housing bolts ddgonzal 2019/4/3 8:19
           Re: 60A bell housing bolts ddgonzal 2019/4/3 9:27
       Re: 60A bell housing bolts TexasMidget 2019/4/4 2:50
       Re: 60A bell housing bolts benny 2019/4/4 3:42
         Re: 60A bell housing bolts ddgonzal 2019/4/4 8:59
           Re: 60A bell housing bolts nickmitty 2019/4/5 2:12
       Re: 60A bell housing bolts TexasMidget 2019/4/5 5:14
         Re: 60A bell housing bolts ddgonzal 2019/4/5 6:01
       Re: 60A bell housing bolts TexasMidget 2019/4/5 6:16
         Re: 60A bell housing bolts benny 2019/4/5 7:38
       Re: 60A bell housing bolts TexasMidget 2019/4/5 10:40
         Re: 60A bell housing bolts ddgonzal 2019/4/6 1:24
       Re: 60A bell housing bolts TexasMidget 2019/4/6 3:10
