Re: 60A bell housing bolts
From Fort Worth, Texas
DD... I read the Tech Wiki on the pilot bushing which is supposed to be on the end of the crankshaft and typically does not need to be replaced. However my motor has a bushing inside of this pilot bushing. I wonder if the pilot bushing needed to be replaced and the mechanic could not remove it and pressed in another bushing and ground down the drive gear of transmission to make it fit. Once I get the inside bushing removed, then we can see what is going on.
Posted on: 2019/4/6 3:10
Subject Poster Date
     60A bell housing bolts TexasMidget 2019/3/26 2:16
       Re: starter motor bolts ddgonzal 2019/3/26 4:13
       Re: 60A bell housing bolts ddgonzal 2019/3/26 5:21
       Re: 60A bell housing bolts TexasMidget 2019/3/27 3:10
         Re: 60A bell housing bolts ddgonzal 2019/3/27 3:51
           Re: 60A bell housing bolts ddgonzal 2019/3/27 4:06
       Re: 60A bell housing bolts TexasMidget 2019/3/27 4:08
         Re: 60A bell housing bolts ddgonzal 2019/3/27 4:53
           Re: 60A bell housing bolts coxsteve 2019/3/31 3:31
       Re: 60A bell housing bolts Rallytwit 2019/3/31 19:24
       Re: 60A bell housing bolts TexasMidget 2019/4/1 5:32
         Re: 60A bell housing bolts ddgonzal 2019/4/1 11:01
           Re: 60A bell housing bolts ddgonzal 2019/4/1 11:44
       Re: 60A bell housing bolts TexasMidget 2019/4/2 3:56
         Re: 60A bell housing bolts ddgonzal 2019/4/2 6:20
           Re: 60A bell housing bolts ddgonzal 2019/4/2 7:36
         Re: 60A bell housing bolts ddgonzal 2019/4/2 7:49
       Re: 60A bell housing bolts TexasMidget 2019/4/3 3:23
         Re: 60A bell housing bolts ddgonzal 2019/4/3 3:50
       Re: 60A bell housing bolts TexasMidget 2019/4/3 4:27
       Re: 60A bell housing bolts TexasMidget 2019/4/3 4:46
         Re: 60A bell housing bolts ddgonzal 2019/4/3 8:19
           Re: 60A bell housing bolts ddgonzal 2019/4/3 9:27
       Re: 60A bell housing bolts TexasMidget 2019/4/4 2:50
       Re: 60A bell housing bolts benny 2019/4/4 3:42
         Re: 60A bell housing bolts ddgonzal 2019/4/4 8:59
           Re: 60A bell housing bolts nickmitty 2019/4/5 2:12
       Re: 60A bell housing bolts TexasMidget 2019/4/5 5:14
         Re: 60A bell housing bolts ddgonzal 2019/4/5 6:01
       Re: 60A bell housing bolts TexasMidget 2019/4/5 6:16
         Re: 60A bell housing bolts benny 2019/4/5 7:38
       Re: 60A bell housing bolts TexasMidget 2019/4/5 10:40
         Re: 60A bell housing bolts ddgonzal 2019/4/6 1:24
       Re: 60A bell housing bolts TexasMidget 2019/4/6 3:10
