« 1 ... 14 15 16 (17)
Re: Kermit the beat up Sedan
From MOOROODUC. Victoria
Bought myself a new timing light and am now REALLY confused.
The motor seems to run a bit rich but that's not the confusing bit - It seems to be timed at about 40 degrees BTDC with the timing light but when I manually line up the rotor button to point at the No.1 plug it's 5 degrees - the only thing I can think of is that someone has put a wrong pulley on the motor at some stage because there's only one mark and its on the front of the pulley (I thought there were supposed to be about 5 marks on the engine side of the pulley).
What's going on??? - Any advice?
Posted on: 2/9 8:44
Red 1200 Coupe
Blue 1200 Ute, CA18DE Auto (Silvia in disguise)
Green 1200 Sedan stock standard (Kermit)
Yella Terra Sedan shell for sale
Mustard sedan shell
Red sedan auto shell in planning
From Adelaide
Is the vacuum advance hose connected? If so disconnect it.
I had to mark TDC on the timing cover and pulley with a white pen just to see it with the timing light.
Posted on: 2/9 9:59
1200 Coupe A15E - ITB
Lamb Daiquiri - a man's cocktail!
From Hawaii, USA
Yeah that's irrelevant. To statically set timing like that you want to go where the breaker points open. At 7 degrees BTDC
5. Rotate housing anti-clockwise -- slowly -- until a spark appears at the coil wire
6. Tighten distributor hold-down bolt
See Initial Timing
Posted on: 2/9 11:24
Went to the Nissan Datsun Nationals and got a nice surprise.
https://m.facebook.com/story.php?story ... 289&anchor_composer=false
Posted on: 4/27 9:44
Red 1200 Coupe
Mustard sedan shell
From Sydney
Great recognition for the hours of work you put into the resto.
Posted on: 4/27 10:04
1971 B110 Sedan GX Spec
1970 KB110 Coupe Track Car
1970 KB10 Coupe
S13 caliper b...
From Mordialloc
Now then, its time to get one with the Coupe and stop wasting your conciderable efforts with models that have too many doors
( "sound off stockwhip cracking" )
dp
Posted on: 4/28 7:48
'79 B120 (TURBO EFI A15 + 60 ser.5spd )
'83 Clubman 7 with worked A15 + 63A 5spd
'73 1200 Coupe Mild A15 5spd lsd
keep it simple
From melbourne
found today .. FREE 2 DOOR Shell
B310 panelvan shell only. No diff, no front suspension. Free to take away. Need room for a new project so needs to go or I'm cutting it up and taking to the tip.
https://www.facebook.com/marketplace/item/1174120852760613/
jpg  b310.jpg (52.66 KB)
14887_5cc5559b64a33.jpg 416X288 px
Posted on: 4/28 8:27
dp
Just a little taste
jpg  Sneak peek.jpg (63.54 KB)
8710_5cc55b876e194.jpg 1008X490 px
Posted on: 4/28 8:51
Red 1200 Coupe
Mustard sedan shell
From Look who's back in town
Damn would love that b310 tow bar! Don't scrap that
Posted on: 4/28 13:50
Was B110 Sedan: L series
Now b310 L series
Congrats demac on the win
Now b310 L series
