« 1 ... 4 5 6 (7) 8 »
Re: Datsun 1200 A15 build
From Canberra
So i have not posted much lately unfortunetly due to funds not much has happened got the engine all sorted with parts runs a dream
got all the other parts in just a few things to finish
ill make sure to do some more updates and some pictures of what has been really happening
jpg  10256330_10152038063896148_4470075481169071716_n.jpg (82.61 KB)
16063_539a89bf348a0.jpg 720X405 px
jpg  10369167_10152038096436148_5979003090891139916_n.jpg (96.42 KB)
16063_539a89d8afb61.jpg 720X405 px
jpg  10374976_10152038064011148_7971440228895688492_n.jpg (34.74 KB)
16063_539a89de65007.jpg 405X720 px
jpg  10437439_10152038063801148_4091631252024260680_n.jpg (82.26 KB)
16063_539a89e5a6d55.jpg 405X720 px
jpg  1969197_10151891432451148_1159496988_n.jpg (73.06 KB)
16063_539a8c3bd4237.jpg 540X960 px
Posted on: 2014/6/13 6:19
looking awesome mate
i love a-series builds!!!
Posted on: 2014/6/13 13:58
Re: Datsun 1200 ute A15 build
From Hawaii, USA
Great look!
Got any pics of the engine?
Posted on: 2014/6/14 4:57
From Canberra
Thought i'd be kind enough to go ahead and login and give a full update on the datsun A15 build as its been some very long time
The car has had many changes, its been through 3 different engine setups the A15 with the twin webers, it A15 blow through carby, and now an all out custom A15 EFI turbo setup
The rig run down now is as follows;
Wisco Pistons 40 thou over bore and fire ringed
Max speeding rods
ARP Studs
236@50 Camshaft
Tomei 1.5mm MLS Headgasket
Tomei lightweight pushrods
TOmei Double valve springs
Tomei seats collars and retainers
Custom Dizzy with Halleffect
Custom Crank trigger pick up 60 -2
Custom NFNR intake manifold - TPS sensor added
Custom Turbo manifold
Garret T25 Turbo internally gated
750 Seiemens Injectors
Custom surge tank with lift pump and inline 044 pump through all aeroflow AN lines and Fuel Reg - Return to tank setup
Haltech Elite 750 ECU
Haltech Wideband controller
Haltech sensors and distribution block
Custom Direct clutch 190mm brass button clutch
Toyota Steelcase gearbox with dellow conversions bellhousing and holden W series clutch fork
New tailshaft
R31 diff with billet 31 spline axels
Running Straight E85
not sure if i have missed much else besides CAN inputs, MAC valve and specific sensors but happy to advise
Only just really sorted some issues had with the ECU and got it started over a week ago just need to do a few little things sort out vaccum lines and other little peices make sure its buttoned up completely then take it to get tuned with a mate and see what power we make, with the setup around the 14 psi hoping around the 120-130kw should be acheivable and if wanting ram that boost up and should definately see above those 200hp
https://www.youtube.com/watch?v=KcuGhD2Oasc
Video of first start of it Turbo Efi
jpg  22308803_10154684133056148_2650304801791214919_n.jpg (131.30 KB)
16063_5cf85671cf0ac.jpg 768X960 px
jpg  39878844_10155360839921148_540823806625710080_n.jpg (112.77 KB)
16063_5cf8567766874.jpg 768X960 px
jpg  49937875_10155634873131148_2957925667309617152_o.jpg (103.04 KB)
16063_5cf8567d37777.jpg 1080X652 px
jpg  62360531_10155908753891148_5897590469411471360_n.jpg (131.91 KB)
16063_5cf856f626f8d.jpg 960X960 px
jpg  62343201_10155908753951148_1609545586950799360_n.jpg (83.04 KB)
16063_5cf856fdd7b2d.jpg 720X960 px
jpg  62121708_10155908753981148_8912862046136041472_n.jpg (76.87 KB)
16063_5cf85702992bc.jpg 720X960 px
Posted on: 6/6 0:57
Edited by loosekid on 2019/6/6 5:40:43
From Canberra
Video of first start of it Turbo Efi look above this post for the all new info and build
Posted on: 6/6 1:00
Edited by loosekid on 2019/6/6 1:51:18
Re: Datsun 1200 ute A15 build - Now EFI TURBO
From Adelaide
That's a pretty setup! Any clues on cost of manifolds etc.? I had a look at the Facebook page but nothing jumped out. I could see a lot of machining so I can't imagine it's cheap.
Posted on: 6/7 13:04
1200 Coupe A15E - ITB
Lamb Daiquiri - a man's cocktail!
From Canberra
NFNR Manifold from South Africa Modified for my needs from williem cost me $1300.00 thats with no injectors or any of the AN fittings check valves ect.
The turbo manifold a close mate does fabrication for work and made the manifold along with another mates manifold as a high mount for a T2871 turbo
The manifolds only cost me the price of the steampipe which was really nothing i designed the collector and had it cut
You wont find anything really on FB of prices or what not but if your really interested in the NFNR parts i have contact numbers for a bloke who is doing the import of the parts and postage to your door. The guys have everything you could need for what you may want i did most myself as many of the things they do i wanted top shelf items verse there simple crank trigger setup from a voxel astra and having tiny Fuel line setups, they dont have the parts or resources we do like with haltech at our door or being able to just drop into rocketperformance and get speedflow fittings.
Happy to answer any questions of further detail on the build, wiring ect
Posted on: 6/11 10:04
From Melbored
Box is a w50 where did you get that?
much stronger than t50 albeit heavier
Posted on: 6/11 15:01
why you are slaves to Usury https://www.youtube.com/watch?v=FEheU28ea3c The Anzac Deception not know by modern Australians http://www.anarchistmedia.org/pdf/The-Anzac-Myth.pdf ""
From Canberra
The W50 - Toyota Steelcase can be found nearly anywhere here in aus as there were used behind so many holdens, fords, chryslers ect with 6 or v8 they cheap to get your hands on much easier to find and use then a crappy t50, albeit alot cheaper then a T50 as well cause they are so readily available
Strong boxes, dellow conversions sorted out the bellhousing for me and we used a holden W series clutch fork that is cut down as they very long and welded. The bearing carrier was machined for the thurst bearing
The bellhousing, pivot ball, speedo gear, clutch fork, gaskets, weld on yolk, uni joint, slip joint ect cost me $1700 from dellow jeff is a great bloke and was always willing to help out.
Posted on: 6/12 5:52
From Adelaide
I'm interested in the gearbox conversion.
Did Jeff machine the T50 Bell Housing differently to suit the W50? I guess he could if the casting was close enough.
Did you have to send any parts to his shop?
Did you get the tail shaft done locally after you had all the other bits?
I have a W55 or similar that I picked up and hoarded years ago with the thought of fitting to the A15. Never got around to investigating further....
Posted on: 6/12 11:12
