Fast Search Slow Search
Google Ad |
Browsing this Thread:
1 Anonymous Users
#1
WTB Turbo Manifold for the A-Series
Budgiesmugglerz
Posted on: 2019/5/19 23:04
Looking for a turboi manifold.
THANKS
#2
Re: WTB Turbo Manifold for the A-Series
Volodkovich
Posted on: 2019/5/27 23:41
Intake or exhaust manifold?
#3
loosekid
Posted on: 2019/5/28 12:13
id assume he means exhaust being turbo..
If you want something hit up NFNR (find them on facebook) in South Africa They do alot Including EFI intake manifolds for turbo setups william is his name Can build your setup as well for you.. Or if your wanting to do carb or something else.. the next option just find any reputable exhaust/fabrication shop they can easily make one for you myself and mates have made many apon many turbo manifolds its not overly hard the collector is the only hard part but can source flanges and collectors online from shops as well to suit i.e t2/t4 flanges
#4
Mattndew76
Posted on: 2019/5/28 16:56
I am making a 1018 mild steel CNC machined one soon, but most wont enjoy the price.
#5
D
Posted on: 2019/5/29 2:00
I cant find the articles but to save time, money, driveability and engine life
Log style manifolds have proven to be better pre-5000rpm than longer equal length. After 5k rpm for 4v heads and 6k rpm for 2v heads the difference is 10-15% peak power. Whilst torque is substantially fatter in log style manifolds street applications. VW, Fiat and Peugeot have some 1.2-1.4L turbo gas engines that make crazy torque equal to NA v8 engines using log style manifolds, small turbo combos etc. Turbo A series could be made to have a very healthy 1400-6000 rpm powerband than having nothing happening from 4k rpm before they wake up from a coma. On a similar note Austin Minis are getting 100hp atw from 1000cc engines using AMR500 on very simple manifolds like the one below and seeing even simpler compact billet ones that could also be made for Datto A setups. https://www.vmaxscart.co.uk/s/cc_image ... 75966619.jpg?t=1508591295 https://www.vmaxscart.co.uk/injection-mini-supercharger-kits/ [img width=500]https://www.vmaxscart.co.uk/s/cc_images/teaserbox_2475966619.jpg?t=1508591295[/img]
#6
zigmondo
Posted on: 2019/8/7 13:59
Have just joined NFNR on Facebook to enquire about their EFI manifolds
Was not happy with the one I made so these guys look like theirs will fit my application on the Clubman7 - cost will be the factor as to whether I go with them or try again dp
#8
D
Posted on: 2019/8/12 5:02
It would take halve a brain SFA to DIY your won EFI inlet manifold these days
will all the bits available online. Roland Twin weber manifold with cheap brass injection inserts (heaps of patterns) 250-300 aud all up https://www.google.co.jp/search?q=bras ... _AUIEigC&biw=1326&bih=658 https://poojametal.com/brass-inserts-for-mouldings/ Xcessive manufacturing plenum 225usd https://xcessivemanufacturing.com/niss ... ms-flanges-ui-efp-n1.html or even cheaper 20 bucks from centre road wreckers and diy cut up a Hyundai v6 inlet ![]() use Permatex 84209 PermaPoxy 4 Minute Multi-Metal Epoxy to bond it all and self tap inserts for extra strength onto flat piece of alloy plate to act as a flange to sit between them you can port flange to taper into manifold inlets and Bobs your Aunty. cheap and easy for any halve wit prob less than 700aud and will look awesome As for exhaust manifold better pay someone to do one and if you do an inlet design as mentioned above, then you can pay even for a billet unit with leftover change from what some of these advertised custom ones are priced at.
#9
zigmondo
Posted on: 2019/8/13 5:01
Reply to D - I looked at using a twin weber manifold but its not for a Datsun 1200. I have a chassis rail that would be in the way so it needs to be more "upswept"
Good idea though dp
#10
D
Posted on: 2019/8/14 0:12
