« 1 2 (3) 4 5 6 »
Re: A15 turbo manifold build
From Mordialloc Victoria 3195
Started again from scratch
Cut the twin webber manifold in half and swapped LHS to the RHS and vica versa
to get better exhaust manifold clearance and a smaller plenum size.
This revelation came to me at 3am in the morning
jpg  IMG_1709.JPG (111.52 KB)
16236_5d71f3686e0c2.jpg 600X450 px
jpg  IMG_1710.JPG (194.43 KB)
16236_5d71f378eda5e.jpg 800X600 px
jpg  IMG_1713.JPG (158.60 KB)
16236_5d71f384cc4f8.jpg 800X600 px
jpg  IMG_1714.JPG (158.75 KB)
16236_5d71f39f35632.jpg 800X600 px
Posted on: 2019/9/6 6:51
keep it simple
Mock up of the A15 turbo setup - no its not in 1200 but hey.
dp
jpg  P1010010.JPG (158.53 KB)
16236_5d7b4557c9df1.jpg 640X480 px
Posted on: 2019/9/13 8:31
Edited by zigmondo on 2019/9/14 8:33:47
keep it simple
Thats more the spirit, no use paying for those high end manifolds
when something like that will give the same power.
Glad to egg you on so you had another go at the weber mani
I hate seen people spend 1.5 to 2k for a 4cyl manifold its so
not datsun in spirit but each to their own.
Posted on: 2019/9/14 13:49
Ha Ha Ha - Yeah. After a few false starts , its starting to move along.
I'm really happy the way both the inlet and exhaust manifolds worked out.
It should be a fun drive when its done !
dp
Posted on: 2019/9/14 22:20
keep it simple
The only thing that could have been better to achieve that angle
was to angle cut the inlet wall by making the plenum a little longer
at the front and have the throttle flange welded on to have it bolted up.
like this but a little longer and opposite angle etc
Posted on: 2019/9/15 1:01
Edited by D on 2019/9/15 3:28:18
Edited by D on 2019/9/15 3:28:52
D - I looked at doing that with the first throttle body I was going to use but this 52mm one is off a Suzuki TL1000 motor bike
(small , light and compact) so its only a flex hose coupling (support will off the front of the head)
It has an added bonus of a built in injector boss which could be used for secondary injection ( water , meth , etc )
dp
Posted on: 2019/9/15 6:57
keep it simple
yep now confirmed petrol meth head!
Posted on: 2019/9/16 8:01
Motor nearly done
jpg  IMG_1751.JPG (141.27 KB)
16236_5d837282b50d2.jpg 2016X1512 px
jpg  IMG_1750.JPG (131.53 KB)
16236_5d8373ac95ddc.jpg 2016X1512 px
Posted on: 2019/9/19 13:20
keep it simple
From Adelaide
What pistons are you using? They look like flat tops. Tell me more...
Posted on: 2019/9/19 21:06
1200 Coupe A15E - ITB
Lamb Daiquiri - a man's cocktail!
I forked out for forged pistons from SPS in Melbourne.
Slight dish 9.2:1 ( turbo on E85) not cheap
Will possibly do another down the track and be more experimental
dp
Posted on: 2019/9/20 3:17
keep it simple
« 1 2 (3) 4 5 6 »
