#1 Damn Running Problem Again
Frodaddy Posted on: 2004/7/2 4:37
I just put a 32/36 Weber on my car and it was running fine for a day until I took my coil off and painted it. When I hooked it back up it ran with a really bad miss. I have made sure there is no paint on the terminals and the wiring is correct.The same problem I fixed on the original carby by connecting the vacuum advance tube which had come off. I need help. Any suggestions???
#2 Re: Damn Running Problem Again
Frodaddy Posted on: 2004/7/2 4:41
Also, when accelerating the engine cuts out at 3000 rpm and bogs and splutters.
#3 Re: Damn Running Problem Again
ddgonzal Posted on: 2004/7/2 5:02
Maybe another hose got knocked off? But I doubt that would cause a problem at 3000rpm. Maybe the coil wires are switched?
#4 Re: Damn Running Problem Again
A14force Posted on: 2004/7/2 23:17
Get a multi meter and mke sure that the coil is getting ballisted voltage.
#5 Re: Damn Running Problem Again
Frodaddy Posted on: 2004/7/5 2:57
Thanks guys but I replaced the points which were actually broken. Runs like a dream now.
