WTB wide bolt pattern steering knuckle arms
From MOOROODUC. Victoria
I need a set of 80 mm bolt centre knuckle arms.
Any out there?
Posted on: 2019/11/3 2:36
Re: WTB wide bolt pattern steering knuckle arms
From sydney australia
Are these for the Stanza/180B/200B based struts? I have some Sunny steering arms left over from a Sunny. If you can't find anything in Vic, you can have them for the price of the postage.
Posted on: 2019/11/3 2:47
They need to be 80mm bolt centres. The smaller ones are 75mm. Sunny should be ok but if you could check that would be great
Posted on: 2019/11/3 3:23
Sorry for the delay in replying, but I've measured the steering arms I have & they seem to be 80mm spacing. Definitely left & right hand arms. I've taken off the ball joints, & they're currently getting a soak in some degreaser to get all the rubbish off them. This should half the postage costs. If you can give me a mailing address via PM, I can probably get them mailed on Friday. They will need a clean with a wire brush, & probably a coat of paint. After that they should do the job.
They'll need Sunny/Stanza ball joints & Sunny/Stanza lower control arms, unless you have late 1200 ute control arms, which used the bigger ball joint. Stanza ball joints seem to have more offset, meaning wider track & negative camber.
Posted on: 2019/11/5 8:45
Perfect news. PM'd address
Posted on: 2019/11/5 10:25
