« 1 2 3 4 (5) 6 »
Re: A15 turbo manifold build
From Mordialloc Victoria 3195
Have to revise the Intercooler (position/type/size) as its blocking too much air and its getting temps up into the mid 90 degrees mark
dp
Posted on: 2019/12/29 20:29
keep it simple
If you tilt that intercooler so theres air coming from below into the radiator
maybe 30 degrees it should be enough of a gap but will need custom shovel nose
design if you have no room to do this. Something along these lines but simpler
https://i.pinimg.com/originals/01/ba/a ... 31fe9873ca3b3316ff729.jpg
Posted on: 2019/12/30 4:44
Different fan (one big instead of two small ones) , relocated oil cooler and additional radiator cowl
cooling sorted
https://flic.kr/p/2idLfDc
Posted on: 2020/1/17 20:53
keep it simple
If I might ask. Forgive me if you already wrote this but, what are you using as an ignition system? Did you use the factory distributor? What ecu? What size and model injectors. Need help for my own A12 turbo build. Just curious how you did it. Why reinvent the wheel?
Posted on: 2020/1/22 17:19
Used pretty much the same setup as in "datsun 1200 for $1200" - lots of good info on that thread
Ignition/Distributor - 12 tooth motorcycle sprocket(one tooth omitted) mounted inside a gutted standard distributor
with hall effect sensor mounted off the side.
No crank angle sensor
ECU - Microsquirt
Injectors - Bosch/raceworks 725cc on E85
On the second turbo build I used Ls1 coils (simpler because they have internal igniters )
dp
Posted on: 2020/1/23 21:00
keep it simple
From Melbourne, Australia
looking great, didnt realise I missed so much at that bbq...
Posted on: 2020/4/3 6:23
1200 Coupe Weekender
1200 Coupe Rallycar
1200 Coupe Wife's Daily
1200 Coupe Project A15ETT
Its a little off topic but I'm building another chassis for the Clubman 7 because
after living with it shortfalls for several years now - Its time
jpg  IMG_2338.JPG (166.51 KB)
16236_5e8bb193cce64.jpg 700X525 px
Posted on: 2020/4/6 23:48
keep it simple
Posted on: 2020/10/19 20:28
keep it simple
From Sydney
Outstanding work, must be very satisfying to get the build to this stage....
Posted on: 2020/10/20 0:13
1971 B110 Sedan GX Spec
1970 KB110 Coupe Track Car
1970 KB10 Coupe
S13 caliper b...
Photo of it completed wouldn't load before.
Here it is finished with its clothes on.
Now to dial in the suspension settings - mainly castor
dp
jpg  IMG_2659.JPG (198.46 KB)
16236_5f8e2e57e87c2.jpg 800X600 px
Posted on: 2020/10/20 1:26
keep it simple
« 1 2 3 4 (5) 6 »
