« 1 ... 4 5 6 (7) 8 9 10 11 »
Re: DOHC Front adapter plates
From Coondle, WA Australia
That looks just a little bit fancy!
The idea of the two part setup is just to reduce milling costs?
since you don't have to buy such a thick slab and mill 90% of it out.
I especially like the cutout you have done for the water gallery - thats the bit im most interested in.
Posted on: 2020/2/7 2:20
EARTH FIRST! - We can mine the other planets later...'
'69 Blue 4 door Project Daisy (http://www.datsun1000.com/TopicView.asp?TopicID=668)
(https://pcmhacking.net/forums/viewtopic.php?f=15&t=5640)
(http://mx5cartalk.com/forum/viewtopic.php...
From Creswell, Oregon USA
yeah the two part is to cut out the accessive milling time cost and material cost.
The Cut for the water flow should do the trick without any flow restrictions.
Posted on: 2020/2/7 3:20
An idea doesn't work unless you do.
Instagram @MD_Machine
Parler @MDMachine
Looks great but cant see the belt setup in my mind
that is limited in bandwidth! Holy Smokes though!!!!
Posted on: 2020/2/8 5:18
im keen as mustard to see some photos of the final product and how the two parts fit together!
Posted on: 2020/2/8 5:50
me too as I cant work out in my scone
how on earth the belt runs etc.
Posted on: 2020/2/9 0:01
The belt runs in the same pattern as on the original steel plate.
The photos I posted show the plate with the crank shaft end up on top.
Posted on: 2020/2/9 3:58
Parler @MDMachine
Call me a dunce but I still cant picture the original steel plate
with the waterpump somewhere in there. its eating me up inside
Posted on: 2020/2/9 12:14
Water Pump bracket hasn't been designed yet but it will occupy space where the alternator is on the
A12.
Posted on: 2020/2/9 20:21
Parler @MDMachine
good to know it is missing a piece of the puzzle
its reduced slightly the puzzling brain fog.
So you are saying Matt the mid dizzie a12 not the
earlier front dizzie A12 right?
I can get an a12 easier than a15 atm so was thinking
of A12 sleeved for 81.25mm 4age pistons, A14 crank,
A12A rods or H beams for 1597cc.
Being Pmd by Miata freak that the earlier and later
B6 heads are easier for cams from ebay chinese units.
SO will aim for this in my first build but really
want the Z head to maximize weight and performance.
He informed me the Mazda B6 head almost mirrors the
Toy 4age and the Maz Z the Toy 4afe which a good site
like Billzilla.org lists a full works 4afe making 248hp
with less head work than what TRD and Yamaha perform to
get a formula atlantic 4age to make the same hp.
Really love how Jap engines swiped the cosworth and lotus
designs then made them avail to bottom feeding enthusiasts.
Posted on: 2020/2/10 4:16
Even if it was the front dizzy A12. A crank timing setup can be adapted to this plate as easy as HRC taking Russian money.
Posted on: 2020/2/10 4:41
Parler @MDMachine
