Re: Help on Coupes (engine mods)
From Whetstone,Arizona
Dear Bloxhamd,
Both engines use a Forged steel crankshaft and the blocks have 5 main bearings. With good pistons
and a balanced rotating assembly you should be able to run all day at 6000 Rpm. I would have the crank polished and keep the bearing clearences close then do a slow break-in
period. The A15 will pull
harder at lower RPMs and you may not need to keep it at 6000 or above as much. The piston speed is
marginal anyway on such a short stroke engine !
Rev-On Dude
C-Ya Steve
Posted on: 2000/3/10 11:16
Re: Help on Coupes (Hi Dave)
From Mudgee NSW Australia
Hi Dave how is your project going?? havnt spoken to you for quite while. As you can probaly see my car is going quite well with a respray happening soon. Its going to be white this time
so it draws less attention to it. Im also getting rid of bonnet scoop as I have found when it rains my coil packs get wet and after a while start to missfire :( anyway if a stock A14 or
A15 was balanced 6500-7000rpm would be attainable would need double valve springs or else would start to bounce at around 6200 :)
Cya Andrew
Posted on: 2000/3/10 7:42
« 1 (2)
