Distributor timing
From MOOROODUC. Victoria
Maybe a dumb question and I may have my own solution but here goes.
I just got my dizzy rebuilt for the coupe which has electronic ignition. I went to reinstall and set the timing marks to TDC on cyl 1.
Isn't there two TDC's ? ... one for compression and another for exhaust? So I took the oil filler cap off and worked out that the TDC with the first valve down was probably the exhaust stroke and the next rotation would be the TDC I need.
But it still will not start and backfires
Any thoughts?
Posted on: 2021/6/7 4:55
Re: Distributor timing
From Armidale N.S.W
Take off the dizzy cap when you turn the engine to tdc (by hand)rotor button should be pointing to number 1 plug or #1 lead on dizzy cap from memory. Possibly 180 degrees out.
Also are your leads in the correct direction and firing order ? 1,3,4,2
Posted on: 2021/6/7 5:02
73 1200 wagon SOLD
If you remove the #1 spark plug (the front one!) and put your thumb over the hole you can feel the pressure when its on the compression stroke as it approaches 0 degrees. Be turning the pulley clockwise. Try and advance it a bit say 5 degrees before TDC and set the dizzy up so the rotor lines up with the #1 lead. Start the car and then set the timing from there.
As Datsandy says check the firing order 1342 and remember that's in the counterclockwise direction.
Posted on: 2021/6/7 12:45
Thanks guys. Both confirmed my assumption of the second time that the crank rotates number 1 piston up and the valves are both closed that this is the right stroke. Then i should insert the dizzy so that the rotor points to number 1 plug lead. Yes I have the right order of 1342 anticlockwise
Will play again on the weekend
Posted on: 2021/6/7 23:56
