Trav and J Wolf have found the SR20DE crankshaft fits with little work into the qr engines
this was done when the 2008 revised edition of the qr25de with full counterweight crank
from factory and also as an alternative to the SR20DE stroker sleeved engine.
1.15:1 compression pistons are available from 2jz racing as used in NA 2jz engines
https://www.2j-racing.com/media/catalo ... mg_20200706_144503874.jpghttps://www.2j-racing.com/2jr-high-comp-piston-set-11-5-1-qr25.htmlCanam forged pistons also available that can be used
https://canampartsguy.com/product/40152m09200/?v=24d22e03afb2https://canampartsguy.com/wp-content/u ... 43b-9bf1-79055d3c65e1.jpg2.0L
QR20DE SR20DE custom rods, QR25DE cams induction and exhaust for 8-9000rpm 200hp
2.2L
QR25DE using SR20DE crankshaft and custom rods can rev to 8-9000rpm with no issues to make over 220hp.
90mm bores dont need sleeves whilst 92mm bores are possible with sleeves
2.4L high rev
91mm J Wolf crankshaft, rods, cams
2.5L Stock with bolt ons (rods limit it to 7k rpm)
QR25DE post 2008 is a serious bit of gear an improved version with full counterweight
100mm crankshaft that with with bolt on 200+hp has been done in the US for over a decade but limited to FF or FWD
2.7L QRazy
92mm sleeves, pistons, rods and stock crankshaft
The engine is lighter and more compact than the SR20DE
with the only obstacle a rwd gearbox.
Now if only I can get hold of an old N10 Pulsar for
a QR27DE with AWD Sir setup.
