NEED HELP(Which Throttle Body)
From Goulburn NSW
Hey Guys,
Im in need of some advice to choose which throttle body size i need.This is for a stroker ca18det motor,the plenum will be make by Custon Plenum Creations.Any advice would be much appreciated.
Cheers Mcdat.
Posted on: 2022/9/5 1:06
Re: NEED HELP(Which Throttle Body)
Which throttle body size for a plenum depends on the horsepower you will be regularly targeting
* stock CA18DE (131 hp) 42mm/70mm
* stock CA18DET (167 hp) 55mm/70mm
* modded CA18DET (400 hp) 68mm
The smaller number is the size of the throttle bore & throttle blade, the larger is the external pipe connection
You can go a bit smaller if you will rarely be revving the engine up to the peak HP
Posted on: 2022/9/5 3:43
