« 1 (2) 3 »
Re: Unleaded fuel questions again.
1200GXman
Firstly, i think you are writing "valve guide" but really mean "valve SEAT" This is the round ring that is inserted into the head & is machined so that the valve can seal the combustion chamber.
The valve guide can be seen up in the port & the top of it protrudes into the rocker area. These are to guide the valve as it moves up & down.
If you do suffer valve seat recession, the tappet clearance will close up, eventually to nothing. Then the engine will run rough, & if you keep driving it, you will likely burn out one or more exhaust valves. By this stage you will need to pull the head off for repairs, to find that they have NOT eaten their way into the aluminium.
Woody
You can not legaly buy leaded super grade fuel in NSW. I suspect that you are using "Lead Replacement" super, the same as I do. If you read the label at the bowser [fuel pump] in the service station, it will say "lead replacement". It is now being phased out by some companies.
Posted on: 2004/7/22 14:29
Love your Datsun.
Treat it well.
From Kingston , Brisbane
If your Jeep is running a pre-crossflow Ford 6 the head will be cast iron.
Posted on: 2004/7/22 22:11
From Coondle, WA Australia
250 precrossflow. Yes cast iron for sure.The ole infamous log head.
Posted on: 2004/7/23 0:26
EARTH FIRST! - We can mine the other planets later...'
'69 Blue 4 door Project Daisy (http://www.datsun1000.com/TopicView.asp?TopicID=668)
(https://pcmhacking.net/forums/viewtopic.php?f=15&t=5640)
(http://mx5cartalk.com/forum/viewtopic.php...
hey all sorry for runnin off topic heeps...
why are they called the log head.... this motor dosent miss a beat!
so being cast iron that means i MUST use the flash lube right?
thanx
Posted on: 2004/7/23 0:50
78 model datsun 1200 ute. A15 twin webbers, dogleg 5speed.
Jk Rubicon unlimited, 58 CJ3B Willys
Sure does I think they called them log heads because they are heavy ,I bet the manifold is cast onto the head .
Posted on: 2004/7/23 1:13
yeh im pretty sure the manifold is cast...
Posted on: 2004/7/23 1:14
Quite a regular
After all this discussion i'm still a little lost. Can someone tell me if I can run unleaded in my A12? Sorry i'm not very mechanically minded.
Posted on: 2004/7/23 2:43
From Invercargill, New Zealand
Yes - it won't cause any problems.
Posted on: 2004/7/23 3:06
not to hijack the thread too much, but the loghead was named due to the excessive weight, and that it as an ugly head both to look at and performance wise. with a cast on manifold, and unimaginative design, the head asnt a powerhouse. What saved this motor was its capacity and torque.
Basically its an ugly lump of underperformaing cast pig iron hence the nick name loghead. At least thats from my experience.
Still, not a bad donk overall. like you said, it never skips a beat. Throw a crossflow head on, and its a huge hp boost, plus all the dogifing options.
To make me feel a little better, running unleaded in an a series will do em no harm, and you ill need seom sort of lube additive like flashlube ith a cast iron head.
ahhhh, got that all out, ,much better.
Posted on: 2004/7/23 4:18
From South Africa, Bloemfontein
Dodgeman
You 100% understood what I ment.
Basically why I am asking these questions is that I want to go over to unleaded.
If it damages my valves and the stuff Dodgeman mentioned I will then take off my head and prepair it for unleaded.
I am actually bargaining that this will never have to happen. But in this process I do not want to damage my head in ANY way as it is a genuine GX head.
I will cry myself to death if it gets damaged.
If only the valve guides gets damaged then I will replace them when they are damaged.
Thanks for all the replies.....
Posted on: 2004/7/23 6:32
1977 Datsun 1200GX
« 1 (2) 3 »
