« 1 2 (3)
Re: Unleaded fuel questions again.
From South Africa, Bloemfontein
DAMN IT!!!!!!
I just phoned a Cylinder Head repair shop.
The guy said that as far as he could remember all datsuns that came in the 70's to south africa has copper valve seats or a soft metal valve seat.
He said that over time these will wear out and I will have to replace them with hardened valve seats for unleaded.
As far as I remember Dodgeman is busy with this on his GX head.
I will maybe do it then next year.
While my cylinder head is of I can admire the nice and new looking cylinder bores asif they have'nt driven even 2 kilometers while in fact they will have about 70 000km on them by that time.
My datsun is a daily driver, mostly because I enjoy driving it.
Posted on: 2004/7/23 10:08
1977 Datsun 1200GX
Baloney! No heads come with copper valve seats.
The same 'warnings' and 'dire predictions' were made here in the US prior to phasing out unleaded. Nobody has needed to replace valve seats.
In any case all A-series cylinder heads have replaceable valve seats and replaceable valve guides, so why don't you just wait and see what happens?
Posted on: 2004/7/23 17:04
From Invercargill, New Zealand
Sounds like the Cylinder Head guy is only remembering as far as his wallet! I don't think even pre-war English motors would use copper valve guides! Datsun certainly didn't and it sounds like you are starting to get yourself stressed out again by doing too much research on this. Many of us on here have been running unleaded in these motors for over 5 years with absolutely NO problems - and yes these are daily drivers.
Posted on: 2004/7/24 2:29
Teretonga
When 1200GXman writes "guides" [in an earlier post] he actually means "seats" & if you look at the inlet seats of an A12 head [at least the early ones] they have a brass-like appearance. The exhaust ones are of course, a suitable grade of steel.
I have no idea what these inlet seats are made of, but they sure do look a lot like a brass derivative.
The actual valve guides, as we all know, are steel [sometimes refered to as iron]
I don't know what the story is with L series engines, but none of the fuel companies recomend using LFF [lead free fuel] in these, so my 200B soldiers on by using lead-replacement fuel.
Posted on: 2004/7/24 2:52
Love your Datsun.
Treat it well.
In the US we don't have LFF vs LRP -- I think all fuel has lead-replacement additives. in any case we have run the A-engines for over 15 years on unleaded.
Posted on: 2004/7/24 4:06
From Stone Age somewhere in U.S.A.
not meaning to add to the braindamage, I feel a need to clear up a few things.
the US has been using unleaded fuel since 1975, that means that we've had to put up with it for almost 30 years.
up until about 1978, all Nissan/Datsun vehicles sold in the US came with hardened bronze intake seats, and hardened steel exhaust seats, after that Nissan began to install hardened steel valve seats in both intake and exhaust seats.
use of unleaded fuel will cause the valves to "sink" into the seat, however the majority of wear will occure to the valve not the valve seat, because the seats are harder than the valves. when this happens, all that is necessary is to recut the valve seats and install a new valve. (this is assuming that you already have hardened steel seats in your head) bronze seats will, over time wear out and need to be replaced even with leaded fuel. the cure for this is to use the engine normally and when it's time for a rebuild, have hardened steel intake seats installed as part of the valve job. my own had over 100,000 miles (160,000 km.) on it when it came apart, being as unleaded fuel has been used in it WITHOUT any lead substitute for over 20 years, all that was necessary to return the head to factory spec was to replace the bronze intake seats with hardened steel seats, reface the intake valves, replace the exhaust valves because of stem wear, and recut the exhaust seats.
IF you believe all those horror stories about unleaded fuel, your an idiot, yes the octane sucks, and the lead aint there to help the valves last a few thousand miles longer, BUT IT WON'T DESTROY YOUR ENGINE.
Posted on: 2004/7/24 5:36
From durban, south africa
correct me if i'm wrong, but we have ali heads, ali is soft, so the seat has to be hardend, so you can run unleaded no problem.
since my rebuild(5000km) i have used unleaded no problen at all with high compression.
just use it i've had no problems even with my 1200!!
what is you octane rating over there we get a 95 and 97 unleaded
Posted on: 2004/7/25 17:43
VW chassis
fibreglass body
A-14
280 cam
ported head shaved 1.5mm
extractors with 2inch s/s pipe
webber 38 dgas.
to come........
Dellorto 36 drla
turbo
and then maybe some gas
To clarify an earlier point, my InterEurope Datsun 1200 workshop manual says that the inlet seats are made of an aluminium/bronze alloy, which is why the South African cylinder head speacialist refered to them as "copper"
This is of course of no consequence since it's the exhaust seat that needs to be a very hard steel.
Posted on: 2004/7/25 22:52
Love your Datsun.
Treat it well.
« 1 2 (3)
