#1 mods for l16
independentslider1 Posted on: 2004/7/25 18:03
i am putting a l16 in my 120y
i want to know what i can do to the engine
i want to know the ratio for a 3/4 race cam
so i can get my cam done
do u think it is possible for me to get 160 bhp from the l 16 engine
#2 Re: mods for l16
ddgonzal Posted on: 2004/7/25 19:12
I would think not with a 3/4 race cam, which is old 1960s technology. To get 100hp/liter wouldn't you need a full race cam, or a modern camshaft (high lift, fast opening)?
#3 Re: mods for l16
L18_B110 Posted on: 2004/7/25 23:00
if you slip in the L18 crank and pistons (2mm overbore), with a fairly serious cam, comp, big valve/port head, and twin sidedraughts you can get there.
I don't know where you are (fill in you're profile), but this link for Tighe Cams in Brisbane will help on cam specs http://www.tighecams.com.au/profiles3/nissanlseries.htm. You want something like the 525C (76 Works) grind. Old technology isn't all bad...this is a works rally grind from the 70's
#4 Re: mods for l16
dazzasute Posted on: 2004/7/26 2:37
why not go L18 or L20b??? size isn't much different (block size)
#5 Re: mods for l16
pro-240c Posted on: 2004/7/26 2:55
i would turbo an L16 for that kind of power.
L16s have an almost perfect 1.8:1 rod/stroke ratio - which means they love to rev and do so more reliably. sure they're low on torque compared to an L20, but add a turbo and you're adding torque.
torque x rpm = horsepower.
you already have the rpm ability, so add the torque with a turbo and the rest writes itself....well....with a bit of research, time and fabrication it'll write itself...
i personally would lean to a high CR / low boost application with an L16, but that's not to say you won't enjoy a low CR / high boost application, just adding another option for you to consider.
#6 Re: mods for l16
woodydat Posted on: 2004/7/26 3:54
haha what abouts a Z24 crank in a L20b then slap on sum injection and a snail shell
#7 Re: mods for l16
independentslider1 Posted on: 2004/7/28 4:37
i found some 11:1 compression pistone from a mazda
do u feel they cam work
they are the same 83mm bore
just have to do some machining for de con rod
#8 Re: mods for l16
independentslider1 Posted on: 2004/7/28 5:14
i checked the chart but i dont under stand it
can u help me with which grind is the fullrace grind
in barbados we didn't get alot of l18s so i would like to know the bore of the l24 and if thepistons can work in the l16
which valves and springs do u use when converting the head to a big valve head
thanks for ur help as this is the first time i am modifying an engine and need guidence
#9 Re: mods for l16
datto_dave Posted on: 2004/7/29 7:27
how bout this L20 block and crank, Z20 rods Z24 pistons L20 head with port work, twin 45s/injection
dave
#10 Re: mods for l16
independentslider1 Posted on: 2004/7/29 20:53
In barbados those engines are hard to find
the only lseries that u can find is the l16
that is why i am working on a l16
but would love to find a bigger L series 4 cyl
can the con rods from the l24 fit the l16
because that would be a simple way to raise
the compression
