Browsing this Thread:
#1 How much for a brand new fuel pump?
Freak Posted on: 2004/8/3 7:42
How much will a new fuel pump cost me from somewhere like repco?
I think the old one is packing it in. After 1st and 2nd gear changes at 6500rpm at 100km/h in 3rd it starves its arse out. Just started happening in the past few weeks and when i put the fuel pipe into a bottle it came out pretty slow.
#2 Re: How much for a brand new fuel pump?
ade Posted on: 2004/8/3 9:59
why not rekit your old one??
#3 Re: How much for a brand new fuel pump?
Dodgeman Posted on: 2004/8/3 10:16
Of course you could always make sure that the fuel filter is not partly blocked. Try fitting a new one, after all, they are cheap, readily available, & easy to fit.
The symptoms you describe can be caused by the filter & you will kick yourself if you buy a new pump & it doesn't fix the problem.
#4 Re: How much for a brand new fuel pump?
Freak Posted on: 2004/8/3 10:16
as i've heard that for a small amount more you can have a new one
#5 Re: How much for a brand new fuel pump?
Freak Posted on: 2004/8/3 10:18
Dodgeman i've already tried that. It hasn't had a fuel filter for weeks.
