will it fit
im 15 and dont understand all these numbers 4 different engines boxes and diffs and im thinking about doing my first transplant and was wondering how much trouble it would be to fit a bluebird TRX 2litre motor and 5speed box into my 120y
Posted on: 2004/8/10 15:38
Re: will it fit
It is not all that big a job to do IF....
You have a suitably equiped workshop available
You have a reasonable knowledge of mechanics & have the ability to do much the work yourself.
You know where to get the work done that you are unable to do yourself
You have enough money to pay for it all
You are prepared to pay for, & go through the engineering inspection if you plan to run this on the street.
You may well need to upgrade suspension & brake systems too, & fitting the trans may require some body surgery in the trans tunnel area, so perhaps it might be better to start out small by maintaining the car untill you learn how it all works, then have a good look at conversions that have been done by others to see what works best.
This way you learn from other peoples mistakes. Saves a lot of grief that way.
Oh yeah, the engine in series 1 & 2 Bluebirds are of the "L" series family, & the 2 liter is an L20. There was an earlier six cylinder version of the L series in 2 liter, so the four cylinder version became correctly known as the "L20b" engine as it was the second L20 engine design.
Posted on: 2004/8/10 15:47
Love your Datsun.
Treat it well.
Re: will it fit
From Sydney, Australia
All good advice. We sometimes forget that not everyone knows what we know..
I sometimes forget what I know..
Chris
Posted on: 2004/8/11 0:40
Re: will it fit
make a budget and then double it.... you will need all the $$4 you can get
Posted on: 2004/8/11 13:01
Re: will it fit
thanks for the help i do have a decent work shop and good knolage as i have 3 120ys and have swapped and rebuilt engines with the help of my dad i have been working 2 jobs scince i was 13 so $ isnt a big deal and i have the bluebird as well so it is possible wat surgery will the tunnal need to fit the box in thats the bit wat concerns me
Posted on: 2004/8/11 13:12
Re: will it fit
From SA the place to boost
an l20 will be a pain in the rear because they are fairly tall, try and swap the bluebird for a 180B as the L18 are 20mm shorter and then use the 180B engine crossmember with the extra hole on either side of the chasis to bolt it up. all bolts up like it was ment to be there.
Posted on: 2004/8/11 13:16
Re: will it fit
wat about a 200b so go for the 180b will be easier
Posted on: 2004/8/11 13:38
Re: will it fit
From Brisbane, Australia
it will fit easily in the 120y - they have a massive trans tunnel and were released with L series engines in other markets.
You should be able to find lots of info on this swap if you use the search function, as its been discussed a few times before.
I have it on pretty good authority that the Stanza x-member should fit too, which would suit the L20 sump/dipstick location. Take your trusty measuring stick to your local wrecker and see for yourself. Otherwise use the 180B x-member and sump on the L20, and you'll have to modify the dipstick location on the L20 block.
We are talking about the L20 Bluebird, and not the horrible SIII Bluebird CA20 motor aren't we?
Posted on: 2004/8/11 23:47
