Re: Which engine should i use??
Sorry about that: Stock Datsun 1200 21 seconds is the 1/4 mile time. 0-60mph/0-100kph is 15 seconds.
0-60 mph 15.1 secs
Overview of the Datsun1200 HP and Performance
Posted on: 2004/8/11 9:04
I still have my doubt.
Which specs will my car have +/- with the A14 engine.
Posted on: 2004/8/11 10:48
'74
Quite a regular
From Sydney, NSW
Hmm i like those grille's .. got nothing to do with motors, but thought i say it anyways.
Posted on: 2004/8/11 13:50
"You can't beat what you can't catch!"
From Perth, Australia
This is the beauty and the danger of asking a question such as yours, Razor. Somtimes I'd get the feeling that you will get as many different answers as the number of people you ask. The good thing though is that there is a LOT of expertise to be found here and that is what makes this site the best of its kind.
Back to the point though (and here is yet one more opinion to add to the discussion), I'm a big fan of the A14/ 15 conversion. The upgrade doesn't require major modifications and you don't need to be a Mechanical Engineer in order to complete the job. Once fitted, it will retain a degree of originality and simplicity to work on. On the flipside, a CA18DET gives you injection, Twin Cams/ Turbo and and modern technology but requires more work in the conversion (plus a brake upgrade, gearbox change, etc).
Hopefully this will help you - If you want power and are prepared to pay for it, go the CA18DET and have a ball. If you want mild power, a simple conversion and something easily repairable, grab an A14/15 and put the cost difference into something else on the car.
But whatever you do, remember there are plenty of us here to help you with advice...
Best of Luck and Keep us posted...
Posted on: 2004/8/11 14:00
1974 120Y Coupe
40 thou overbored A14
32/36 DGV Weber
5 Speed Gearbox
New Interior (in the making)
My website
For now i think i will start with a A14 and some time later propably i try to install a turbo on it.
Thanks for your replys and i'lll keep you posted about the project.
I'll open a thread about ir l8r.
Thanks and i hope to get ur help
Posted on: 2004/8/11 17:10
'74
Quite a regular
From South Africa
Hi guys i looked it up for you! The standard B410 A14 ute here in S Africa does 0-100kmh in 13,6seconds and a top speed of 152kmh hope this helps
Posted on: 2004/8/11 19:30
Old Datsuns never die they just go faster
With some mods on that engine, diferent carburetor, 2'' 1/2 exhaust some work modifying some things can i make it 10 seconds? and +/- 90/95 hp ?
Posted on: 2004/8/12 10:24
buy a flinstones motor.. there the best!
Posted on: 2004/8/12 10:32
78 model datsun 1200 ute. A15 twin webbers, dogleg 5speed.
Jk Rubicon unlimited, 58 CJ3B Willys
I had that engine for 18 years.
Posted on: 2004/8/12 11:40
« 1 (2)
