Fast Search Slow Search
Google Ad |
Browsing this Thread:
1 Anonymous Users
#1
Hello...pls help me
TheDude
Posted on: 2004/8/16 10:30
Does anybody have a service manual for a 120Y Sunny Datsun ? Pls help me...i recently brought one and i have no ideea what is under the hood...
I have a proble with it..i have to replace tha cluch piston or something like that...it does not enter in none of the gears... Thank you and excuse my poor english.
#2
Re: Hello...pls help me
woodydat
Posted on: 2004/8/16 10:37
i dont have a manual but i can tell u it wil have an A12 motor if it is stok,..... seeing how u have to change the clutch or wateva, pull the motor out and replace it with an A15 for a bit more go!
#3
TheDude
Posted on: 2004/8/16 10:49
it`s a hatchback...5 doors...i haven`t seen other on the web.....
She loses break liquid.... She consumes vary much oil.... She loses cluck liquid also... Damn...but...it`s a great car for her age
#4
woodydat
Posted on: 2004/8/16 10:51
yeh, id get an A15 they give an increase boost in power, dattos are gr8.
#6
Reeves
Posted on: 2004/8/16 11:06
120y Hatch, havnt seen this one.
Heavy Comsumption of oil- few things, broken, damaged rings or simply sump gasket leak or even sump nut washer needs replacing. Clutch fluid leak- probably slave kit rubbers underneath, next to g\box or possiblly top clutch master cylinder rubers worn out. Break fluid leaks- Rear plunges at back,and front caliper kits need replacing, or maybe broken brake line. The best way to check all these is to put it up on hydraulic ramp etc and carry out a proper check underneath for all these fluid leaks. Onething about dattos, if you fairly mechanically minded, and have worked with other cars, the datto is not that difficult to work on. One normally needs a service manual when specs, elec diagrams etc are needed, however this site, has almost everything you'll need to know about all mechanical question that you may need . Take time to read through the TECH SECTION.
#7
dattodude
Posted on: 2004/8/16 11:10
Dear "TheDude",
Please listen to reeves. Carefully clean all of ther grease and grime off the engine, brake tubes and clutch tube, if it's a hydraulic clutch (not cable operated). Once the engine is clean, you will more easily find the leaks. The engine may need to be reconditioned with new gaskets and seals, possible new pistons, rings and bearings. Chris
#8
Reeves
Posted on: 2004/8/16 11:32
Yo.
Datto's right, clean and then inspect. Use a few bottles of engine cleaner if you have too{Theyre cheap}. Then Hose down, however make sure the distributor is protected from water splashes. Anothjer thing, do you have a pic of this hatch 120y.
#9
evilsim
Posted on: 2004/8/16 16:34
i scanned the entire datsun 1200 book - and its online somewhere. if u want it just PM me and ill send u the URL.
http://datsun1200.com/modules/myalbum/photo.php?lid=3166
#10
A14force
Posted on: 2004/8/16 23:11
You could perhaps try a library for a manual. Or perhaps a technical book store.
