Re: What bits do you need for a single 42mm sidedraught webber?
From Sydney.au
you might need the linkage kit for your weber. if so - get a linkage kit which matches your inlet manifold. apart from that just some spare fuel line hose might be needed.
the linkage kit is good as it has new rubber spacers for between manifold/weber and a few other bits which are required.
goodluck
Posted on: 2004/8/19 7:47
Subject Poster Date
     What bits do you need for a single 42mm sidedraught webber? SILVERBAK 2004/8/19 1:52
       Re: What bits do you need for a single 42mm sidedraught webber? evilsim 2004/8/19 7:47
