Fast Search Slow Search
Google Ad |
Browsing this Thread:
1 Anonymous Users
#1
Help Needed! 1200/120Y Suspension
Frodaddy
Posted on: 2004/8/23 12:29
Will Datsun 120Y Struts fit in a Datsun 1200 Coupe with no modifications and would lowered 120Y springs fit on 1200 struts. I am guessing the springs might as they should be the same width as 1200 springs??
#2
Re: Help Needed! 1200/120Y Suspension
woodydat
Posted on: 2004/8/23 12:44
hey sorry to hi- jack the post, but while were on the subject of 120y's ive been told that the hole 120Y disc brake front end while bolt straight in to a 1200 ute?? i live near the bush and i seen a 120y burnt out upside down with discs. id take the struts, tie rods etc out if it will bolt straight in
nothin like a free be!
#3
ANGE
Posted on: 2004/8/23 13:03
yep.. 120y disc brake front end will bolt straight into a 1200...
#4
woodydat
Posted on: 2004/8/23 13:09
AWSUM! il have to go for a ride out the bush now and see if its still there!
#5
Dodgeman
Posted on: 2004/8/23 13:50
If you use this system, then you will need to use the front brakes, the master cylinder, & ideally, the whole rear axle assembly in order to get the matching rear brakes. This will guarantee a balanced system.
#6
A14force
Posted on: 2004/8/24 5:56
Hey, Fro, I asume that your looking at regulators struts?
#7
pro-240c
Posted on: 2004/8/24 7:05
i used stanza struts, 200B girlock calipers, 180B master cyl and 1200 sedan rear drums and i had NO balancing issues whatsoever. the fronts and rear would ALWAYS lock up together. the 1200 (B110s) rear drum slave cyls are the same volume (even if they're slightly a different shape) as sunnys (B310s), 180Bs (P610s) and 120Ys (B210s). the only way you'll have balancing probs is with bigger front calipers and an accompanying m/c to suit them. and even then, a simple proportioning valve is a lot easier to install / plumb into your existing one than installing the WHOLE braking system off another car entirely. whole rear axle assembly....?!
#8
Frodaddy
Posted on: 2004/8/24 11:25
Ya, I am looking at Regulator's springs and lowering blocks.
#9
b310gx
Posted on: 2004/8/24 12:09
even if you find it's an australian assembled car,the struts will fit.all you need to do is use 11/16 rear wheel cylinders,or you'll wear out the rear brake shoes.the good news if it's a late 120y,these discs & calipers are originally fitted on sigmas,so they are very understressed.i almost had a police car run into the back of me when he was stopping me for speeding,& the car 'only' had the pbr calipers & discs.the only downside is you need the 120y front wheels if you're still on 12 inch steelies,& some 13 inch mags won't fit.i think it has something to do with the diameter of the centre part of the hub.in my opinion,if they're free,grab em.
