chain drive diff
From Perth Western Australia
Hi guys
got a decent project at uni, build a formula sae car. Just trying to pick a few brains here, any ideas for a diff that we can run via chain drive???
the idea is to run a honda CBR600 engine and gearbox, and run the chain straight to the diff.
Posted on: 2004/8/30 7:36
Re: chain drive diff
no diff, just get a balanced inch bar, and drive it off that, use a key to get drive to the wheels and a bolt and a pin throught the end to hold em on!
Posted on: 2004/8/30 8:07
78 model datsun 1200 ute. A15 twin webbers, dogleg 5speed.
Jk Rubicon unlimited, 58 CJ3B Willys
um.... well... we were going a bit more high tech than that....
independant rear suspension, that kind of thing...
and i remember you mentioning something about rear mounted vehicles understeering once... and now your saying go a solid axle????
Posted on: 2004/8/30 8:18
yeah true, so ur goin independent? u shoulda clarified more in ur post.
like i said to u before, look at the set up most modern cars have, and adopt it from that, if i was u and was goin for a light wait and well handling car, id go double wish bone suspension, with a solid axle that runs to the side of the kart were a uni conects to another solid axle which connects to a uni that connects to the wheel, u shouldnt need to much wheel travel so u should be pretty safe. and as for the need for the shaft from uni to uni goes, try a cup and ball set up where the axle has a little round ball at the end of it which fits in to a cup, the cup has to slits in it which a little pin fits through the ball of the axle.
i think it is a good idea and i would be using it for sure.
Posted on: 2004/8/30 9:27
From Perth Austarlia
Which uni do u go to?????
Posted on: 2004/8/30 10:21
Curtin... do we have a spy here???
Posted on: 2004/8/30 10:48
I think I smell manure..........
Yep.....Bullshit..
You don't go to Curtin...
The only team in WA that runs a CBR motor...................is..................
UWA!!!!!
Your identity has been revealed!!!!!!
You should probably run a Ford 9 inch diff. Any serious race car uses one.
Posted on: 2004/8/30 11:55
Harley trikes [Servicar] used a chain drive diff, but these are a live axle, & are a bit hard to find in Australia.
What did the S600 Honda sports car use? I always thought it was a chain driven diff, but i have never seen one.
Posted on: 2004/8/30 13:07
Love your Datsun.
Treat it well.
From Brisbane, Australia
no reason you can't adapt a chain ring to a Quaife LSD (or whatever) and custom CV driveshafts (you wouldn't run power sapping uni joints). Not uncommon on motorbike powered hillclimbers. I'd suggest getting along to a hillclimb and talk to some of those guys.
Posted on: 2004/8/30 13:08
mr DATSIK...
what uni do you go to??? Let me guess... Curtin... (why else would you tell me to go 9 inch) and your name... Brett????
I admit, I'm not in the current Curtin team. But I most certainly go to curtin...
my profile has read "engineering student at curtin uni" ever since I joined the forum...
Posted on: 2004/8/30 16:18
(1) 2 3 »
