#11 Re: Adjustable coilovers
scrubber Posted on: 2004/8/30 23:41
HEY DATMAN i've been chasing a set up like the one at ur web site just wondering if the adjustable strut tops are needed if u have a adjustable lower control arm (rose joint set up) or would both be better? did u manufacture the strut tops ur self? and could u send me some info on spring and damper setups? thanks mate any help appreciated
#12 Re: Adjustable coilovers
datman55 Posted on: 2004/8/31 0:09
PM Sent dude.
#13 Re: Adjustable coilovers
sunny Posted on: 2004/8/31 5:33
the tops look familiar ?
you could also start with r31 skyline struts but then you'd have ventilated rotors . bugger . if your spring is too short and might fall out ,you can run a tender spring to hold them in place , (a small flat wire spring)
#14 Re: Adjustable coilovers
2332owner Posted on: 2004/8/31 5:36
Yeah I'm starting with R31 struts, cutting them down and using AE92 inserts and coilover kit and strut tops from Pitroad. I figure the stock R31 brakes ought to stop it fine and they fit under 13" wheels if you cut down the backing plate.
« 1 (2)
