« 1 2 3 (4)
Re: top speed out of a fair stock a12
From Canberra
bigger rims would cause a lower reading than actual wouldnt they?
Posted on: 2004/8/31 7:08
From Invercargill, New Zealand
Larger circumference rims will decrease your standard speedo reading. Stock A15 in a 1200 with 4 speed depends on your diff ratio and how high you rev. Genuine 160 kph with out downhill or wind assist is achievable. There will be no speed difference between the 4 and 5 speed if the top gear final ratio is the same. If it is an overdriven 5 speed then you may find that 4th is your fastest gear - depends on whether engine has enough torque to rev out an overdriven 5th.
Posted on: 2004/8/31 7:22
Not too shy to talk
From Adelaide
i have a 1000 coupe with an a14 it has a weber and extractors and had it past the 100mph mark slowing down is an intersing consept with drum brakes all round sorry dont have a and rpm count coz the banana that owned the car before me took the tacho out.
Posted on: 2004/8/31 9:16
From Palmie, New Zealand
well ive managed to get 90mph reading off the standard 1200 sedan speedo, that was revving quite high on 15" rims with 45 profiles, would it put the reading out by like 5k's at most or what? and obviosuly the speedo itself isnt accurate anyway, even with standard tyres etc correct?
Posted on: 2004/8/31 10:04
From South Africa
My 1200 delux speedometre is reading pass 160kpm
I ####ed it up once while on a long drive on a flat long stretch of highway, where I attained this speed, and is now stuck at that point since.
Obviously, thats not true speed.
However it felt nice seeing it there.
The 1200's stock with 12' rims, no mods, except the 1400 carbi.
But I wouldnt take it to these speeds ever again,whilst being stock.
Damn, this motor was screaming its ass out.
Posted on: 2004/8/31 12:09
Life's a bitch, so f...k it.
From Christchurch NZ
I used to have a C20 van. It had a bog stock A15. I put 15" wheels on it with215/60 tyres to compensate for the obscenly low diff. Even with these being the least aerodynamic vehicles ever to be fitted with an "A", I still had it RIGHT of the clock, at 140+kph. At that speed the back wheels left the ground momentarilyover the "dips" north of Kaikoura.
Posted on: 2004/9/1 8:02
Forced Induction!
I had my A12 sunny at 135 km/h before it started to rattle and make bad noises :P found out later twas exhaust manifold had 1 and a half bolts in it hahahaha almost killed the ol gurl, my mate road it off later that day whilst drunk...........'sob'
Dave
Posted on: 2004/9/1 12:41
From Sydney.au
last long road drive i had the needle at around 90mph (around 5k revs) at one stage and ran out of safe road. i never get a good enuf chance to max it on 100. damn corners.
stock a12, 4-spd, 2" exhaust/headers, single dcoe.
Posted on: 2004/9/1 14:52
From Canberra, Australia
when my car was stock I took it up to 160kph (100mph) out the back of mitchell (in ACT).
Standard coupe engine, diff, 4 speed and wheels.
that was with the 30 year old engine in it....
I think my new engine does the same only easier... never really pushed it...
Posted on: 2004/9/1 15:40
1971 Datsun 1200 Coupe
A15 Engine. Holley G180 (32/36 Weber). extractors and 2 inch exhaust.
Standard 1200 4 speed with lightened fly wheel and HD clutch
Stanza front struts and brakes.
15x6 CSA Wheels with 195/50 rubber.
« 1 2 3 (4)
